View Poll Results: What motor would be the best to power my go kart?
Voters
39. You may not vote on this poll
  • Electric motor
    21 53.85%
  • Air compressed motor
    18 46.15%
Page 18 of 63 FirstFirst ... 8910111213141516171819202122232425262728 ... LastLast
Results 171 to 180 of 628
Thread: Solar panels?
  1. #171
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon
    Quote Originally Posted by 2k1Toaster View Post
    It needs about 450F to 550F (depending on the quality of solars extracted) to liquify them enough to bond them together.
    How you get the heat is up to you. You can use a flame torch, but you would have to be very careful as direct flames will ruin it. The oven is the safest.
    Wouldn't it work better if he just put it in the oven, locked it, and set it to "clean"? That way he wouldn't even need a timer. (I can feel the flames now)
    My opinion is my own.
  2. #172
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    the tin foil is for the underside of the lexan to make sure it doesn't melt, so you can use tape, but the adhesive might melt, and then melt the lexan.
    If you do it right, you can fold and crumple it so that it stays without the tape. Just make sure there is no exposed lexan.
    Also, if you don't want to do it in the oven, the method that danielkh posted will work. Maybe. I haven't tried that method yet personally.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  3. #173
    Started best thread ever
    Jun 2008
    Sort of crush up the aluminum foil and shove it up your underside to plug the hole.
    ok i can do that but idk about that. to c if it works i think when i get everything i'll test it on something like wood or something 2 c if it will work for energy.
    could i hook it up to my charger. not charge it. but read what it says on how much it has voltage?
  4. #174
    May 2007
    Lakehood, CO
    The clean cycle would be a good idea before he puts the paste on it, because it will burn off any unwanted fingerprint residue or chemicals or dust. Then put the paste on, and bake, but you have to watch it.
    It might work a little faster in the microwave, but make sure you put it on power level 9, 10 is too much and will definitely melt the lexan.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  5. #175
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    If it ends up like this, you overdid it.
  6. #176
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by danielkh View Post
    The clean cycles on oven are in the 900F range I thought? Also by law in the US once they get to that temperature the oven must interlock shut until it gets back below 600F or so. So that would just melt it flat out.
    Good idea though
    1.9in x 2.9in -- 47mm x 73mm
  7. #177
    Jun 2008
    Quote Originally Posted by monkeyracer View Post
    have you tested this method though?
  8. #178
    Mar 2006
    Quote Originally Posted by Ausi319 View Post
    It wont bond to the wood. Also the smoke from the wood will infuse into the solar spread, making it useless. So it will be a waste of money and time trying it on wood.
  9. #179
    May 2007
    Lakehood, CO
    I've tested the microwave method. But make sure the hamster is not installed, because they don't last long in there. (Maybe about 3 seconds or so) A microwave cooks things about 15 times faster than a convection oven, so give it about 90 seconds in there to make sure the paste sets right.
    If you are going to test it, the only way to make sure it would work is to use the same plastic as the car body; lexan, so you would have to find something similar. Tupperware bowls are made of a similar plastic, so it should work the same.
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
  10. #180
    Mar 2006
    The aluminum foil acts just like it does on a pie or casserole. When you cover it with foil it prevents burning.
  1. Solar power
    By 20mg in forum Hardware Development
    Last Post: 05-28-2009, 06:41 PM
  2. Solar Panel(s) as power while car is off
    By mattst88 in forum Power Supplies
    Last Post: 07-04-2006, 01:37 PM
  3. Solar Panels
    By Rocky388 in forum General Hardware Discussion
    Last Post: 10-24-2005, 01:38 PM
  4. solar panels for dead batteries??
    By kelseymonster in forum Power Supplies
    Last Post: 07-05-2005, 11:57 PM
  5. What about solar panels?
    By Deep in forum Power Supplies
    Last Post: 05-17-2005, 05:00 PM
Tags for this Thread
