You need to rethink how much things cost, or frequent a junk yard.
1.9in x 2.9in -- 47mm x 73mm
if its a 24v motor
what if i used 3 9v rechargables?
would that b too much for the motor?
Say....do you think you could power this thing with solar panels? It might make it run longer.
Want to:
Good batteries will cost $60 EACH at a MINIMUM. Not total. $60 worth of batteries means you will be going to the end of your driveway before it gives out.
Motor if a used pull could be free or $50. New probably over $100.
And how are you going to get 24v out of 9v? I really hope your math does not show 24/9 being an integer.
hey i have the frame and everything done i just need the motor and batteries... (the steering will b done soon)
