View Poll Results: What motor would be the best to power my go kart?
Voters
39. You may not vote on this poll
  • Electric motor
    21 53.85%
  • Air compressed motor
    18 46.15%
Page 50 of 63 FirstFirst ... 404142434445464748495051525354555657585960 ... LastLast
Results 491 to 500 of 628
Thread: Solar panels?
  1. #491
    Constant Bitrate kibble's Avatar
    May 2008
    Quote Originally Posted by Enforcer View Post
    It must suck to be you guys.
    It's already been done. By philips no less
    http://www.projected.co.uk/philips-30hm9202.htm
    Yes it's been done before, but that can't display and be a mirror at the same time. There's even some cell phones that have a "mirror" on the outside LCD, but that's not the point. It's the method used by some to try to obtain these results that's funny.
    Kids, don't play with too many knives! -Crack Stuntman
  2. #492
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If you want, I'll edit the poll answers to include some of the suggestions. Just post them up below!
    Want to:
  3. #493
    Started best thread ever
    Jun 2008
    hey i'm back.
    for my go kart...
    when i get the money i was thinking an electric motor.
    the one you guys/girls showed me.
    I was also thinking of having 2 -4 cheep 12V batteries.
    But, having a plastic box(kinda like a body of a car)
    around the kart.
    for this the top of the kart(roof) will hold a solar panel i make.
    Then on either side.
    All the panels at around...(25V) i guess
    1. Need what will charge 24V or what ever batteries are when i connect them?
    2. Where to get broken solar cells so i can make my own?
    is this a logical thing that might actually work?
    Oh yea...
    3. How to tell with a solar panel(from broken solar cells) how many milliamps it sends into the battery at a time. (and also how many milliamps the motor takes to run at the same thing for the panel)
    3. How to get somekind of hard plastic or something to put on outside of kart?
  4. #494
    Jun 2008
    hello???
    Is anyone going to try to help me at all?
  5. #495
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    You need a multimeter for electrical monitoring
    Use Sintra for hard plastic panels
    Ebay "Solar Panel" > Start Spending.
    Contact me when these 3 items are done.
  6. #496
    Jun 2008
    I have a charger that will test + and - of a battery will prolly work on this.
    I want to buy broken solar cells so i can get the expirence of making my own(then if i need it in a certain form or shape i can do so)
  7. #497
    Jul 2005
    Motorcity
    Blog Entries
    1
    PM sent
  8. #498
    Jun 2008
    would any battery (12V) charge with a solar panel/cells or would you need a rechargeble?
  9. #499
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Ausi319 View Post
    All batteries are rechargable if you try hard enough...
    1.9in x 2.9in -- 47mm x 73mm
  10. #500
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Good thinking. You can wire them up in series to increase the voltage. Increased voltage makes the cart go faster. Put 4 12 volt batteries in series and you'll have 48 volts of power! If you have 3 or 4 9 volt batteries laying around, you can add them as well to get it up to 84 volts or so. Just remember to wire up your broken solar panels in the same way so the voltage is higher.
    Most solar systems use something called a controller but since you are using broken solar cells, you can use a BRO-K1N controller. Google it and you'll find out instructions for how to make one on the DIY evo sites.
    2K1Toaster gave you the recipe awhile back in this same thread.
    Absolutely. You have taken a very scientific approach to the whole problem so far and have gotten lots of good advice in this thread. I'm sure everyone here is quite willing to help you out.
    If you don't have a multimeter, I think it was suggested earlier that you can use your tongue. Just like on a 9 volt battery where you get a slight tingling when you put your tongue on it. The bigger the shock, the more volts it is sending in to the batteries.
    Want to:
  1. Solar power
    By 20mg in forum Hardware Development
    Last Post: 05-28-2009, 06:41 PM
  2. Solar Panel(s) as power while car is off
    By mattst88 in forum Power Supplies
    Last Post: 07-04-2006, 01:37 PM
  3. Solar Panels
    By Rocky388 in forum General Hardware Discussion
    Last Post: 10-24-2005, 01:38 PM
  4. solar panels for dead batteries??
    By kelseymonster in forum Power Supplies
    Last Post: 07-05-2005, 11:57 PM
  5. What about solar panels?
    By Deep in forum Power Supplies
    Last Post: 05-17-2005, 05:00 PM
Tags for this Thread
