View Poll Results: What motor would be the best to power my go kart?
Voters
39. You may not vote on this poll
  • Electric motor
    21 53.85%
  • Air compressed motor
    18 46.15%
Page 51 of 63 FirstFirst ... 414243444546474849505152535455565758596061 ... LastLast
Results 501 to 510 of 628
Thread: Solar panels?
  1. #501
    Started best thread ever
    Jun 2008
    i think i will just use my charger(it also tells volts)
    but how do i tell how many amps my panel is sending into my battery?
    because that would have to be close if not over what my motor would take to charge it.
    If i could get that to work i could run with the battery all day(for the most part)
    But how do i take how much the panel will give to the battery
    and then how much the motor will take out of it
    (at the same time)(like 1 second for each?)
  2. #502
    Sep 2008
    Quote Originally Posted by Ausi319 View Post
    Use your tongue. If it feels similar to placing your hand into an electrical outlet, then you should probably put on some rubber gloves for protection.
    Remember, only if it feels like an electrical outlet, if not your battery life will be considerably less.
    As for the amperage formula you seek here it is
    where x= your IQ, y= the grams of the broken solar panels, (that's why the absolute value signs are there, in case of a negative number) and p= the fourth root of -3. However since it is impossible to multiply an even quantity of negative numbers together to get a negative square root, you will have to deal with imaginary numbers. I have full confidence in your abilities to handle these problems, as you have proven beyond a shadow of reasonable doubt that you are a smart kid.
  3. #503
    Jun 2008
    hey but would it charge the batteries and or power my kart all the time...
    i will upload pics of what i want to do l8er..
    but will it keep me running for a longer time?
  4. #504
    Jun 2008
    http://www.mp3car.com/vbulletin/atta...1&d=1224535607
    theres somewhat what i'm thinking about
  5. #505
    Mar 2006
    Colorado, but Canadian!
    I doubt it will have enough power to both charge the battery and keep you moving unless it is a sunny day and you are using the yellow petals for increased photon absorbance.
    Also, you can paint the "bubble" as you call it with a bright yellow to attract more light energy, and put the cells on top. Don't paint after you put the cells on, because then the paint would absorb all the light, and not leave any for the cells. The paint is more of a carrot to a horse. Hold in itfront of its face and it goes. Put paint behind the cells and the light wants to get there, but never does because it is intercepted by the solar cells.
    Even though it may not power it and charge at the same time, it will last a little bit longer than if you didn't. But just park it in the garage at night with a large sodium lamp above it, and it will recharge nicely for more daytime use... Unless you are an owl, and want to use it at night.
    1.9in x 2.9in -- 47mm x 73mm
  6. #506
    Jun 2008
    will that help it at all?
    like how long lets say a normal ride thing is around 7 mins
    how much would it affect it at all?
  7. #507
    Mar 2006
    Yes
    The time gained [in inverse Hertz] is proportional to the inverse square of the hypotenuse of the bubble multiplied by the complex conjugate of the electromagnetic plane normal to the bubble (as viewed with the sun being tangential) multiplied by 'K' where 'K' is the coefficient of static gullability.
    The coefficient can be looked up in a table and depends on many factors most of which being the impedance of the solar paste, and the material of the bubble.
    The EM plane has to be measured or guesstimated. Depends where you live, how close to the sun you are, your effective mass (gravity bends light you know). This can be assumed to be equal to (z(pi/2 + jK)) if on Earth around sea level and around no more than 100kg body mass which will simplify the calculation quite a bit.
    The rest is plug-n-chug simple math.
    A lot
  8. #508
    Jun 2008
    like i want it to stop on the outsides of the kart.
    so almost like a square type thing in the front but not...
    like it is a diagonal in the front flat on top and diagonal and then strait down to the back(water proof)
    then a hinged piece of it taken out so i can get in and out.
    (with the leak proof tape stuff that car doors have)
  9. #509
    Jun 2008
    if it was 7 mins how much do you think it would help?
    (around maybe how much more time?)
  10. #510
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    You could see the time double.
    TruckinMP3
    Read the FAQ!
  1. Solar power
    By 20mg in forum Hardware Development
    Last Post: 05-28-2009, 05:41 PM
  2. Solar Panel(s) as power while car is off
    By mattst88 in forum Power Supplies
    Last Post: 07-04-2006, 12:37 PM
  3. Solar Panels
    By Rocky388 in forum General Hardware Discussion
    Last Post: 10-24-2005, 12:38 PM
  4. solar panels for dead batteries??
    By kelseymonster in forum Power Supplies
    Last Post: 07-05-2005, 10:57 PM
  5. What about solar panels?
    By Deep in forum Power Supplies
    Last Post: 05-17-2005, 04:00 PM
Tags for this Thread
