View Poll Results: What motor would be the best to power my go kart?
Voters
39. You may not vote on this poll
  • Electric motor
    21 53.85%
  • Air compressed motor
    18 46.15%
Page 54 of 63 FirstFirst ... 44445464748495051525354555657585960616263 LastLast
Results 531 to 540 of 628
Thread: Solar panels?
  1. #531
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by blk02si View Post
    I just can't handle this much stupid in one place!
    Isn't it better that it is all in one place so you can avoid it than spread around so you trip over it all the time.
    I wonder if you could use a stupid panel to concentrate all that stupid into an accumulator to power a vehicle. Stupidity happens at night as well as during the day, so you wouldn't have to worry about charging during the day only.
  2. #532
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Rob Withey View Post
    HAHAHAHAHAHA something like that could power the entire planet forever.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  3. #533
    Started best thread ever
    Jun 2008
    lol but could it work?
  4. #534
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Ausi319 View Post
    yes it could. These people are just jealous that someone so young is attempting something and can pull it off.
    1.9in x 2.9in -- 47mm x 73mm
  5. #535
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    1. Solar panels DO NOT work at night. They generate electricity from SOLAR RAYS which are not present when the earth's rotation prevents any rays from reaching its surface relative to the panel location. - Astronomy 101, Physics 101
    Sez you! What do you think lights up the moon at night? The SUN. In fact, the moon is a reflector of the sun and therefore concentrates its rays at night otherwise it would be DARK. Using broken solar panels allows you to concentrate it to normal daytime levels.
    2. Perhaps using broken, half working, trashed panels is too complicated for me to understand since it seems like a waste of time. However what I do understand, and obviously you don't, is the basic laws of electricty, since hooking up source panels in parallel will double the AMPERAGE, while voltage remains constant. You will need to hook them up in SERIES if you want double voltage while amperage remains constant. I suggest you take a look at Ohm's law before ruining all your runined panels - Electronics 101
    Okay, you got me there. Too much wine and a quick post don't add up. Aus319 - hook them up in series, not parallel, 'nkay?
    3. I read this entire thread, and half the posts in it are poking fun at Ausi, so you either: A. believe all the posts too... or B. Have not read the entire thread yourself.
    Why don't you try attempting Science before posting in a Solar thread?
    Hah! Right back at you! If your sponsors were car companies, then do you think it was in their interests to find out that internal combustion is inefficient!? Puh-leeze!
    @Aus319 - don't listen to tools of the establishment. Blaze your own trail!
    Want to:
  6. #536
    Jun 2008
    i hope it works...
    how can i get the frame i wanted around the kart though?
    the see though plastic for tat?
  7. #537
    SD beats everything. So there. danielkh's Avatar
    Sep 2007
    Beaverton, Oregon, United States
    The saying "once bitten, twice shy" holds no merit here, does it.
    My opinion is my own.
  8. #538
    Mar 2006
    i hope it works...
    Use your mother's/sisters's/your own/neighbour's hairdryer and heat up the plastic and form it around the metal frame.
    I would go to Home Depot and look at the cost of acrylic though. It isnt cheap. Most of your $61 budget will go right there. Metal isnt cheap either.
    So your grandiose plans about a bubble go-kart on a the budget of a dinner for 1 at a mid-range restaurant is not going to happen.
    Perhaps go to scrap yards and get stuff, or go to manufacturer's and ask for scrap material, or dumpster dive. I got a lot of good oak and mahogany wood scrap from dumpster diving. I am not sure of the legailities of it, but they pay to haul it away, you are just hauling away some stuff for free. And don't go stealing things from construction sites. If it is not in a dumpster, it is not yours.
  9. #539
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Do you have any trash bags at your house? You can make your own ABS plastic from garbage bags. If you parents have any of those good, strong contractor style (usually green or black) or leaf bags that say "outdoor use" on them, you're in luck.
    Get a blow dryer and first cover a form that is the shape you want the body to be with wax paper so the plastic won't stick. Then, layer the bags on top of that. Then, set the dryer on high heat and melt the bags to fuse them to each other. 10 or 15 layers is best for strength.
    For additional strength (and power) coat the surface with the blended solar sludge you are making from busted solar cells. Wire them (in series!) to the rest of the cells and then the batteries You'll have a hand-crafted body in no time.
    Want to:
  10. #540
    Mar 2006
    Or you can use garbage bags and fuse them together in some gasoline... You dont smoke do you?
  1. Solar power
    By 20mg in forum Hardware Development
    Last Post: 05-28-2009, 05:41 PM
  2. Solar Panel(s) as power while car is off
    By mattst88 in forum Power Supplies
    Last Post: 07-04-2006, 12:37 PM
  3. Solar Panels
    By Rocky388 in forum General Hardware Discussion
    Last Post: 10-24-2005, 12:38 PM
  4. solar panels for dead batteries??
    By kelseymonster in forum Power Supplies
    Last Post: 07-05-2005, 10:57 PM
  5. What about solar panels?
    By Deep in forum Power Supplies
    Last Post: 05-17-2005, 04:00 PM
Tags for this Thread
