View Poll Results: What motor would be the best to power my go kart?
Voters
39. You may not vote on this poll
  • Electric motor
    21 53.85%
  • Air compressed motor
    18 46.15%
Page 8 of 63 FirstFirst 12345678910111213141516171858 ... LastLast
Results 71 to 80 of 628
Thread: Solar panels?
  1. #71
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    ok. I revise my previous statement;
    it's possible, just not practical;
    you could put a few solar cells, and a micro-wind turbine, with a small nitro engine hooked up to a little autonator (new invention by the way) with a generator on all 4 wheels to capture all the lost energy in braking, that would generate enough electricity to charge the 2500 mah battery that you should buy for it. But it would weigh so much, you would need a nitro engine to power the back wheels just to get it moving.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
  2. #72
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Look, solar powered RC car:
    [media]http://youtube.com/watch?v=A_EfWi-_b4E[/media]
    [media]http://youtube.com/watch?v=WmVhK7cn8RQ[/media]
    and an instructable:
    http://www.instructables.com/id/Solar-RC-car/
    So yes, its possible. But kind of wimpy so you probably wont be winning any competitions with that.
  3. #73
    Started best thread ever
    Jun 2008
    Quote Originally Posted by Chairboy View Post
    Hey guys, be easy on him. His mind's already made up, he's not interested in facts. It's tough to be 15 years old (when you know everything) and dealing with a bunch of slow witted adults who obviously know the answer to your very simple question and just can't spit it out.
    I might be able to put the hood as a solar panel...
    but where would i have the antenna come out?
    could you drill a hole?
    w8 i can put one in the back and front and get a spolier and put them on that too.
    But how would i keep them from breaking or getting scrached?
    there any easy way of keeping like a little box or something like hard plastic to keep them from breaking?
    like if i would go off a little ramp or hit something?
  4. #74
    FLAC Chairboy's Avatar
    Jan 2004
    With the abundant solar power, there's no reason for your car to fall when it goes off a ramp, it should continue to fly, higher and higher until it disappears from view.
    Chrysler 300 - Fabricating
    http://hallert.net/
  5. #75
    Mar 2006
    Colorado, but Canadian!
    Point is you would need to cover the whole car in them, and even then you would go pretty slow as your car is not built to be lightweight and efficient. It is built to be cheap and mass produced.
    And why drill a hole? There will be gaps between them the antenna can stick out of. And they are glass foremost, so if you are planning on playing rough, you will run out of money really fast as they are expensive.
    1.9in x 2.9in -- 47mm x 73mm
  6. #76
    Jun 2008
    Houston
    We are forgetting the most realistic answer to this problem...MINDPOWER!!!! All it takes is practice, if you stare long enough and hard enough at the car, and you want it bad enough you can will it to go as fast as you want!!!! However it will take lots of practice, you should sit and stare at the car, trying to accomplish this feat, at least 3 hours a day until you get the hang of it. Also it may help if you make yourself a hat out of aluminum foil. This focuses the brainwaves producing more mind power.
  7. #77
    Jun 2008
    Quote Originally Posted by 2k1Toaster View Post
    1.what if i make my own out of broken solar cells?
    2.i need about 1500 mA at 7.2 or so volts how could i get that?
    3.series or parallel?
    4.and i would like to like ramp or something a little.
    also incase if i am playing with friends and were racing if they hit me by accedent it dosnt screw up the solar panel!
    5.also what about them at night?
    someone said they would still work? or just reverse the polarity how could i do that?
    Need all these answers
    number them like i have them in the ?'s
    Thank you!
  8. #78
    Jan 2004
    Yep, to use solar panels at night, just reverse the polarity of the leads. Be careful not to do this when there's any light out, or it will actually suck power out of the car. If there's no power left, it'll start converting the parts of the car that are touching the ground into pure energy.
    http://hallert.net/
  9. #79
    Jun 2008
    what do solar panels use to power?
    sunlight?
    or some thing like radio waves or something we cant c
    because i think its some wave we cant c...
    What if you would make your own solar panel then.
    It would b less expencive and then u could sell them to other people to keep making them.
    how would that work?
  10. #80
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by Ausi319 View Post
    Thank you!
    1. Broken solar cells are actually more efficient than unbroken ones. Remember, the key to solar power is density. By compacting the solar cells, you get far more cell surface per inch than just a single flat panel. I use a BlendTek blender to increase the density of mine.
    2. 1500ma X 7.2v = 10,800MegaAmpVolts. Use ten 1 farad capacitors in parallel to store the energy from the solar cells and you'll be fine.
    3. Series. Definitely. You need a whole series of cells to make this work.
    4. Not sure what you're asking here.
    5. Make sure you are wearing sunglasses or number 1 welding goggles when running the cells at night as the light leaks out it will briefly exceed 1m candlepower. Or, just look the other way and wait for the flash.
    Want to:
  1. Solar power
    By 20mg in forum Hardware Development
    Last Post: 05-28-2009, 06:41 PM
  2. Solar Panel(s) as power while car is off
    By mattst88 in forum Power Supplies
    Last Post: 07-04-2006, 01:37 PM
  3. Solar Panels
    By Rocky388 in forum General Hardware Discussion
    Last Post: 10-24-2005, 01:38 PM
  4. solar panels for dead batteries??
    By kelseymonster in forum Power Supplies
    Last Post: 07-05-2005, 11:57 PM
  5. What about solar panels?
    By Deep in forum Power Supplies
    Last Post: 05-17-2005, 05:00 PM
Tags for this Thread
