Results 1 to 8 of 8
Thread: a little confused...
    Jul 2008
    God evening all, just a quick hello from accross the pond where we drive from the correct, (hehe) sorry, RIGHT seat in the car. (and change gear with he trusty left hand too )
    I have decided i want to have a go at a (budget) first attempt car pc...
    i currently have lying round a spare desktop pc, which was a a p4 1.8 with 1gb of ram.... i assume i can pinch the mobo from this?
    the first issue was that this pc is a dell, but having read the threads on here, i have just had the multimeter out, and am pleased to report it is wired to ATX standard.
    What DC-DC PSU's can be used with this board (if any, im hoping there are!!).... the reason for me asking is, as this is a p4 board (i thinkt thats the reason anyway) aswell as the 20pin atx connector, it also has that extra four pin connector (yellow black yellow black) from the psu to the mother board... do any of the DC to DC power supplies support this?
    thanks for your time guys.
    Ste
    Sep 2007
    West Springfield, MA
    I know the M2-ATX does. I'm sure there are others though.
    Mar 2006
    Colorado, but Canadian!
    Yes the M2 has this wire, as do the Opus line, and the DS-ATX.
    The M2 will NOT power a desktop P4 well.
    1.9in x 2.9in -- 47mm x 73mm
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by 2k1Toaster View Post
    It seems to do OK on the older northwood and williamette based P4 processors. But I've only ever used a 400mhz fsb with the M2 psu. I ran a 1.8 for a little over a year, had a 2.4 in there for a while, then fried my mobo in an unrelated accident.
    Tidder
    Try RevFE
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    The M2 may not have enough watts for your P4. You may want to look into a less hungry CPU. There are some very cheap options out there (smaller too)...
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    Jul 2008
    Its currently a socket 478 cpu which is a p4 @1.8ghz, what do you reccomend instead?
    the current mains psu is only rated at 250w max.
    What sort of whattage would i need do you think?
    Thanks for the help so far.
    Regards.
    Ste
    Mar 2007
    Socal
    The M2 atx and many power supplies are around 160W. You will need to factor in other components besides the CPU (monitor, USB devices, Motherboard, etc). Some P4s use over a hundred watts. By comparison, the new 45nm core 2 duos use 35w at peak.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
    Sep 2003
    New Mexico, USA
    A P4 1.8 should use at peak 75w.
    Tidder
    Try RevFE
  1. im confused with power supplies now :(
    By flavor4real in forum Power Supplies
    Last Post: 10-25-2006, 12:38 PM
  2. Should I change or Let her go?....So Confused
    By BIzFlawless in forum Off Topic
    Last Post: 05-26-2006, 10:27 PM
  3. xenarc came today... confused
    By chrislloyd in forum LCD/Display
    Last Post: 04-04-2005, 09:01 PM
  4. Audigy2 nx bass output confused
    By rickyaswell in forum Car Audio
    Last Post: 10-08-2004, 02:32 PM
  5. Im confused...
    By gsand in forum Software & Software Development
    Last Post: 10-07-2003, 08:10 PM
