Results 1 to 3 of 3
Thread: P2140 Secondary Output not Powering
    Jun 2008
    Finally got around to doing the install. The Primary Out is working fine with the AOpen MiniPC, but the Secondary Output is only outputting .24 volts on the multimeter, thus there is no power to the monitor. Any ideas?
    Jan 2008
    Southern Calif
    Check and re-check your jumper settings and wiring.
    Jun 2008
    Checked it many times. Everything is jumpered and wired correctly. Also had several people look into it. Will be doing an RMA tomorrow.
  1. Replies: 115
    Last Post: 03-05-2011, 03:54 AM
  2. P2140 mini install questions.
    By hondamac in forum General Hardware Discussion
    Last Post: 08-22-2007, 11:23 PM
  3. No output on my BOSS CH350
    By TCPMeta in forum Car Audio
    Last Post: 02-21-2007, 06:33 AM
  4. Help wt. Video Output.
    By grnLude in forum LCD/Display
    Last Post: 01-09-2007, 05:06 PM
  5. tank circuit - what output do I need?
    By maxcosity in forum Power Supplies
    Last Post: 06-03-2003, 04:00 PM
