Results 1 to 7 of 7
Thread: Few questions on M4-ATX
    Jun 2008
    I am going to use 8 gauge wire for the 12v and ground. Does the ACC wire have to be 8 gauge? Has anyone built a plug like adapter to disconnect easily? Did anyone put a fuse(s) inline? What size? I see the M4 has a 25 amp on it.
    what type of enclosure is anyone using? I want to install in my dell and is there an easy way to install?
    Sorry for all the questions but I am anxious to get things started.Thank U.
    Elsewhere
    Quote Originally Posted by flyerman View Post
    No.
    Yes.
    Yes. Definitely put on on the constant 12v line. The debate is out whether it's needed on the ignition-controlled ACC line.
    A 25A or 30A fuse WITHIN 18 INCHES OF tHE BATTERY would be sufficient.
    Remember that the fuse is to protect the wiring, not hte equipment.
    Do you really need an enclosure?
    And you're going to have to get to fabricating. There's no easy means of installing.
    How about the Wiki?
    Jun 2008
    thank you for the quick and informative response.
    Jun 2008
    Yes.
    Can you please elaborate?
    Constant Bitrate kibble's Avatar
    May 2008
    I don't have a quick disconnect, but I'm sure you could use anything that would accept an 8 gauge wire.
    Jun 2008
    I just connected my wiring to the terminal posts: each connection is a possible failure point and can add resistance. I'm just a nOOb at this stuff, but I've been doing cars, bikes and computers (separately!) for years.
    As for cases- I did put my psu in a project case from Radio Shack. Not a major process, and it does allow me to have a dedicated fan forcing airflow over the board while reducing the chance of something shorting out.
    Of course, my whole computer is in... well, more than a single case.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Here is a picture of it inside a PSU enclosure.
    Have you found the "everything you need to know about your M4" FAQ yet?
    Want to:
  1. Replies: 6
    Last Post: 05-25-2005, 11:53 AM
  2. Newbee Questions
    By Ascension in forum Newbie
    Last Post: 04-03-2005, 08:43 AM
  3. ATX board power??
    By Alphared in forum Power Supplies
    Last Post: 01-10-2003, 12:36 PM
  4. Presario AT or ATX?
    By ppgt94 in forum Power Supplies
    Last Post: 04-11-2002, 04:45 AM
  5. ATX and AT motherboard
    By Beavis in forum Power Supplies
    Last Post: 05-10-2001, 02:22 PM
