Results 1 to 10 of 16
Thread: M2-atx 160w
    May 2008
    M2-atx 160w
    Is it possible to use a brick with this supply?
    I need to run off the batts when I'm mobile, But we I'm
    stationary can I remove the batts and run a brick?
    Also if this can be done, what size brick would I need
    so I don't damage the power supply?
    Calvin
    May 2008
    I may have found my answer in the form of a Radio Shack power supply.
    Has anyone tried this setup for temporary power solution?
    Calvin
    Elsewhere
    There aren't many power bricks that put out the amperage needed for the M2.
    I believe you're going to need around 13-15A.
    Good luck findng a power brick with that output.
    How about the Wiki?
    Jun 2008
    Illinoise
    ...... 13 to 15A sounds like alot. I'll research this more, but I have my M2-ATX hooked up to a laboratory DC poer supply, and it maxes out at 4 amps. Haven't even had it get to 3.5A @13.5 VDC yet. Of course I'm running a D945GCLF with only 1 PCI video card, and only 6 USB devices...... low W for healthy car batts
    Any cheap 12vdc/4A (depending on your rig)power supply "should" work.........
    May 2008
    That's the same board I'm setting up.
    I just need to run the ITX, Hard Drive and 2 usb devices when running off the brick.
    I just hate to buy 2 PS's if I could use 1 Ps with a brick.
    Calvin
    Apr 2005
    Queens, New York
    I will let you guys know what happens tomorrow! I Just bought the D945GCLF and m2-atx with a voompc-2 case. I bought everything from mini-box.com as well as an 8.5a power brick.
    Everything should be delivered tomorrow, I should have everything setup by tomorrow night.
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    May 2008
    AWESOME !!!!
    Thanks I can't wait to see how it turns out.
    Calvin
    Aug 2008
    Quote Originally Posted by ctx32 View Post
    Calvin
    I am. My Morex 3777 came with a power brick and I'm using that to run my M2-ATX-HV/Little Falls combo. If you load the PS to the full 160-watt rating at 12 volts, you'll draw a little over 13 amps. But few applications will do that, and if they did, the PS would not be big enough--a continuous draw that high would stress that PS excessively.
    My box also has a 2.5" HDD, an IDE compact flash adapter, and a slim CD drive, that may possibly come on together at the same time once in a while. I suspect it's running at maybe 40 watts except for the occasional brief peak. When I add the monitor, it will be 50 watts. The brick that came with the 3777 is rated at 80 watts.
    I'm also leaving the coaxial plug in place, and will protect it with a diode to prevent reverse current, and will provide battery connections using a power cord with Anderson Powerpoles. That way, I can plug in the brick before unplugging the batteries to keep from having to shut the box down.
    RickD
    Apr 2005
    Queens, New York
    and ofcourse ups rescheduled my shipment until tomorrow... Dont know how much I can do when i get home from work tomorrow because i am leaving for vacation friday morning, but I will try to post what happens tomorrow.
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    May 2008
    Rick,
    I'd like to see how you wire your setup.
    I need power both ways.
    Thanks for the tip on the Anderson plugs
    Calvin
  1. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 11:03 PM
  2. Xbox w/ M2 ATX and PSU convertor
    By MiniRX7 in forum Power Supplies
    Last Post: 11-25-2007, 07:45 AM
  3. m2 ATX 160 Watt - voltage irregular?
    Last Post: 11-16-2007, 11:32 AM
  4. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  5. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
