Results 1 to 6 of 6
Thread: PC Looses power around 20 minutes in
    Jan 2004
    Hi there,
    I have a Dell SX260 and mpegbox.com DSX12VD DC-DC power supply setup and it's working fine (boots up when I start the car etc) but it seems to lose power 20 minutes in.
    Anyone have any ideas on why it's doing this?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    overload?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    overheat?
    Either the PS, CPU or MB. Add fans (temporary) to see if the amount of run time changes.
    If you get more run time it is heat related. Solve the heat then look for the next issue... many times you will find more than one.
    You can also try running the PC on your desk (out of the car with a regular PS) to find out if it is a PS issue.
    TruckinMP3
    Read the FAQ!
    Low Bitrate Beehphy's Avatar
    Apr 2007
    I have also seen failing hard drives do this. I think it was a circuit failure, not a normal motor/head failure
    Once the HD warmed up to some critical temp, it just completely fails, and the computer, not knowing what to do, turns off. The HD makes one or two platter spin-up noises before power off.
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    Quote Originally Posted by Beehphy View Post
    i had that two, but than with the data disk, not the os. Disk was replaced within warenty, but most of the times with cpc its power or temperture.
    Apr 2009
    Hi,
    I'm new to the forum but I've been having a similar problem with my dsx12vd. The pc seems to run fine then suddenly power will start flickering on and off repeatedly. The PC is turning on and off 1-2 times a second! Meanwhile the red status LED is steady on.. I notice the capacitors and even the wires running from the output are hot. I will try applying a fan to the board to see if heat is the problem.
    The PC I have it connected to has a power supply like a laptop type that plugs into the back, that power supply is rated at 18 amps 220 watts max output, but I'm not sure what the PC is actually drawing without hooking up an ampmeter (my next step). Is it possible that I am overloading the power board, even though it runs for anywhere from 5 - 30 minutes before the 'power flickering'?
    TYIA
  1. Hardware Review: M3-ATX Power Suply
    By Bimmerstyle in forum The Review Palace
    Last Post: 03-05-2008, 05:57 PM
  2. 150w PC 300w Power inverter... help?? Please..
    By MINI-Cooper-S in forum Power Supplies
    Last Post: 03-16-2005, 06:25 AM
