Results 1 to 3 of 3
Thread: Carnetix P1900 DOA ?
    Aug 2008
    Just took delivery of a new Carnetix P1900 V2.2
    Applying 13.2 volts (from a samlex SPS-1206 DC transformer) to battery side, but am getting no primary output on regulated side.
    What I am I doing wrong or is this device DOA ?
    Jan 2008
    Southern Calif
    Check your jumpers settings, also check the fuse inside.
    Jun 2005
    chicago, Illinois
    Did you connect your ground (black) to negative and your ign (yellow) wire to switched +12V? Or while the ground and battery is connect, you could pulse the blue pulse wire to ground.
  1. Carnetix P1900 Pulse question
    By Habious in forum Power Supplies
    Last Post: 03-27-2008, 03:58 PM
  2. Questions about my setup and the Carnetix P1900...
    By Nola111 in forum Power Supplies
    Last Post: 05-14-2007, 08:35 PM
  3. Replies: 13
    Last Post: 09-05-2006, 12:44 PM
  4. Carnetix P1900
    By jorgenjl in forum Newbie
    Last Post: 06-22-2006, 01:08 PM
  5. Carnetix p1900 and Travla c138 120watt?
    By john_draws in forum Power Supplies
    Last Post: 05-27-2005, 01:42 AM
