Results 1 to 3 of 3
Thread: need help on fusion brain 25A Relay wireing
    Aug 2008
    Question need help on fusion brain 25A Relay wireing
    ok i have a fusion brain from http://www.fusioncontrolcentre.com
    and i have a 25A Relay from them
    number on the side are pcf-112d2m here is a data sheet
    http://us.100y.com.tw/pdf_file/OEG_PCF.pdf
    i have coil1 and coil 2 going to the fusion brain
    as they come pre wired to connect to the brain
    there are 2 pins labeled #4 no-cont & #3 c-cont
    on the other side is 2 copper plugs also named #4 & #3
    help...
    o can mesure voltages and i can tell pos neg
    but i would know how to wire this relay
    and help
    would be grateful
    ive googled for a few hours and found nothing exept the data sheet and its giberish to me for the most part
    ive wired a uln2003 before and can run it
    but this is higher voltage and dont want to play around to much experimenting
    in the end i want it to power a power strip or just a light bulb
    Aug 2008
    Thanks for all your help here is the answer to my question
    i hope this helps people in the future
    Mar 2006
    Colorado, but Canadian!
    For Fusion Brain questions, I suggest you post in our subforum: http://www.mp3car.com/vbulletin/fusion-brain/
    I dont check the power supply area much at all.
    Looking at what you have in post #2, that is correct. Remember AC doesnt have a + and - full time. It switches at 60Hz or 50Hz if in Europe.
    1.9in x 2.9in -- 47mm x 73mm
  1. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  2. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
  3. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  4. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  5. AMP 1.X Phidget Plugin Interface
    By bcohen5055 in forum AMP
    Last Post: 09-06-2007, 01:10 AM
