Results 1 to 5 of 5
Thread: Suggest on PSU
    Apr 2007
    Wink Suggest on PSU
    Hi guys, since I've always used an inverter to power my athlon machine, now I'm a little bit confused while changing the hardware. The new hardware is an
    Intel 945 based board,
    Celeron 352 3.2GHZ (TDP 85w),
    1GB DDR2,
    80GB Maxtor Pata 7200 RPM,
    USB touchscreen and Holux GPS
    My question as a newbie is about what kind of psu could give appropriate power to this machine. Could a M2 160w be enough? I've heard that the PW-200-M is not a right choice, so.. what do you suggest? Thanks in advance
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    M2 would probably be fine for that.
    Tidder
    Try RevFE
    Apr 2007
    Thanks man! And what about an M3 125w, or a PicoPSU 120w. Could this also be good? I've found that the M2 PSU layout isn't compatible with my motherboard (there's no enough space from cpu cooler to 20pin for the M2)
    Sep 2003
    New Mexico, USA
    What do you mean there's not enough space?
    Tidder
    Try RevFE
    Apr 2007
    I think to place it in the passenger object case (sorry, don't know the exact therm), that is exactly the dimensions of the motherboard. In short, I've to place the M2 ATX on top of the board for space reasons, and this could compromise temperatures.. ok, my explanation is horrible. Only, I think M3 or PicoPSU could be better, as tiniest. Now, since M2 is 160W and M3/Pico are 125W, the PSU are all well dimensionated to pc power requirements?
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 07:55 PM
  2. Remove Case DC-DC PSU?
    By Uther in forum Power Supplies
    Last Post: 08-27-2006, 11:33 AM
  3. M1-ATX 90W PSU Usefull Observations
    By James141 in forum Power Supplies
    Last Post: 03-11-2005, 09:25 AM
  4. Mastero 3.5 12v-12v PSU KIT fs
    By SteveC in forum Classified Archive
    Last Post: 09-28-2004, 12:04 PM
  5. Powering up normal ATX PSU
    By KimaX in forum Power Supplies
    Last Post: 09-28-2004, 01:08 AM
