Results 1 to 6 of 6
Thread: DSATX and Hibernate
    Jan 2006
    DSATX and Hibernate
    So I didn't buy the brainstem, and I just got the DSATX
    If I prefer to use hibernate instead of a complete shutdown, would there be any problems if i use the DSATX in default mode?
    Any suggestions?
    Elsewhere
    No.
    You're basically telling Wondoze how to handle the shutdown pulse bu selecting Hibernate instead of Shut Down.
    How about the Wiki?
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    you will have problems with hibernate or sleep if you will use brainstem!!! I have phisicaly connected brainstem to carpc&DSATX and I can go into hibernate or sleep. If I open com port(hiperterminal) then I can't go into sleep or hibernate...
    Jun 2005
    chicago, Illinois
    The only difference between hibernate and normal shutdown is that hibernate saves the current state of the computer to the harddrive before completely shutting off. And when you power the computer back on, it recalls that information and attempts to resume the computer to the state it was prior to initiating the hibernate.
    Although, standby (or sleep) keeps the computer state stored in RAM before going into a low power consumption mode, and does not completely shut off. This state allows for quicker resume times if not instantanous compared to resuming from hibernate.
    If you happen to have a vista notebook, Sleep goes into a low power consumption mode and allows for a near instantanous resume. In sleep, if battery levels fall below a certain point it will automatically save the state to the harddrive to prevent any data loss before power levels drop completely.
    PROGRESS:
    Jan 2006
    actually i was asking if i need to enable hibernate on the dsatx via brainstem for the entire system-- including the rails, to hibernate properly
    Elsewhere
    Quote Originally Posted by swordfishunter View Post
    What is there to set in the DSATX for hibernation?
    Other than a sufficient time before the DSATX cuts all power, there is nothing to set.
    The PC enters hibernation mode and the DSATX cuts power, as it should.
    How about the Wiki?
  1. DSATX Hibernate Function Fixed
    By zootjeff in forum Power Supplies
    Last Post: 09-30-2008, 03:31 AM
  2. Replies: 2
    Last Post: 06-19-2008, 09:09 AM
  3. Replies: 0
    Last Post: 06-18-2008, 02:33 PM
  4. DSATX and Standby
    By HyperZulu in forum Power Supplies
    Last Post: 06-14-2007, 05:33 PM
  5. DSATX triggering
    By jdiazj1 in forum Power Supplies
    Last Post: 11-17-2006, 02:30 PM
