Results 1 to 3 of 3
Thread: Battery backup for drained SLA's
    Sep 2008
    I know the title sound odd but here is my idea; I started my car up from work and realized, "Crap, my battery's dead". I must have left my lights on. However after a buddy gave me a jump i went home and started working on a plan to remedy this problem (I live in a foggy area, and I tend to leave my lights on). My plan is simple, use four of these diodes (http://pdf1.alldatasheet.com/datashe.../datasheet.pdf)
    put them in parallel so they can handle the current draw, then I use my silicon mats to mount them to the car chassis to dissipate heat. Next I'll make it so the current can only flow from the primary starter battery. After this I will use an 80 amp relay controlled by a switch in the cabin of my car. I am using an 8AH battery which is sufficient for my SUV (KIA Sportage 01). How this works is it keep my primary battery from draining by not allowing the current to pass through the diodes, unless the car has been started, and after the car has been started a relay is setup to go on and charge my battery off of the alternator. So the next time my battery is dead I flip a switch and start my car up as usual. Also the alt in my car is a 136amp 06 Dakota.
    Sound good? Tell me what you think.
    Constant Bitrate insaneramman's Avatar
    Mar 2008
    South Carolina
    Cool Why Not...
    A cheap and easier solution in my op. is this-
    Buy two cheap 25 amp relays (wal-mart) wire your foglamps to come on with your car. Just seems simpler to me.
    Sep 2008
    Quote Originally Posted by insaneramman View Post
    True, but this would also be nice if i drain my car from my power tools, or my audio.
  1. Battery Loosing Charge
    By TeamRSX in forum Power Supplies
    Last Post: 05-15-2008, 11:26 AM
  2. 2nd battery + computer controlled lighting
    By jparks27 in forum Show off your project
    Last Post: 06-02-2006, 09:52 PM
  3. FS on Ebay 12VDC 5.1Ah Ignition Backup Battery
    By TheSpecialist in forum Classified Archive
    Last Post: 03-24-2005, 09:32 PM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. Backup Battery and power converter combo
    By cadence117 in forum General Hardware Discussion
    Last Post: 10-11-2004, 11:33 PM
