Results 1 to 10 of 11
Thread: USing M2ATX without mobo
    Constant Bitrate FockMasterDan's Avatar
    May 2008
    Westerville, Ohio
    I've got a M2ATX that I just want to power my accessories. I've searched and read but haven't found an answer about if there is anything I have to do for that or if it is/isn't possible. Thanks.
    Computer is in the car, but in a very "raw" install right now.
    Worklog - here
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Short the green wire with ground?
    May 2008
    Westerville, Ohio
    You don't sound too confident about that. Can we get a second opinion?
    Worklog - here
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Well with any ATX spec power supply, when you short the green wire to black, it turns the power supply on. However due to design, when you do this with an ATX supply you also have to put a small load (5 watt+) on the 5v rails or else it will burn up (or something like that) if you run it without a load. Not sure how the M2 is designed though.
    Elsewhere
    Quote Originally Posted by nobb View Post
    It's not always green wire to black. It's pins 13 & 14. Some wiring harnesses don't follow the common wire color conventions.
    Pin 13 is the trigger line.
    Pin 14 is a ground.
    How about the Wiki?
    May 2008
    Westerville, Ohio
    Quote Originally Posted by DarquePervert View Post
    Pin 14 is a ground.
    Thanks, so just to clarify 100 percent what should I wire to the trigger line? Are you saying those two pins are just what I have to short together?
    Sorry for asking to be spoon fed this answer, but I've seen so much info on damaging your M2 by wiring it wrong.
    Also any input on needing to feed it 5V to keep it from burning itself up? That seems kind of ridiculous as the M2 is supposed to be fed only 12V power in the first place.
    Worklog - here
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    No, I meant that with atx switchmode supplies, they always need some sort of load when powered on or else it may damage itself. Just something to consider if you plan on powering it up without a mobo attached. I dont know if that applies to the m2 though.
    May 2008
    Westerville, Ohio
    On that note which wire is for the 5V power to the mobo. I could use that for any 5V accessories I may be running (I'm sure there will be something).
    Worklog - here
    Sep 2007
    Raleigh, NC
    I use a standalone m1-atx to power my lcd, hubs, and a couple of other devices. Ive had this setup for well over a year and have yet to encounter any problems. Like darque said, I just jumpered pin 13 to 14.
  1. Advise please.. swap m2atx for m4atx or mobo swap ?
    By ludikris in forum General Hardware Discussion
    Last Post: 03-21-2008, 12:06 PM
  2. m2atx and modern mobo?
    By CMOS in forum General Hardware Discussion
    Last Post: 06-05-2006, 12:01 AM
  3. Asus Micro Mobo and AMD XP-M 45W Barton
    By MatrixPC in forum General Hardware Discussion
    Last Post: 01-05-2005, 06:26 PM
  4. FS: mobo, power supply, CPU etc just look!
    By dannn in forum Classified Archive
    Last Post: 11-01-2004, 10:52 PM
  5. Mobo Woes - Enlightenment needed
    By nzKAOSnz in forum Off Topic
    Last Post: 05-17-2004, 09:24 PM
