1.) 300w??? you don't need anything that powerful for your proposed system. your EEE-box consumes 20w, your monitor will consume about ~10w, and your external [3.5"?] HDD will consume about ~24w (a 2.5" laptop drive will consume even less). that's about 54w total power consumption. and yes they all need regulated power (stable voltages) and can all be powered from a single carPSU.
2.) I don't know of any "in car PC suite", period... what the vast majority of us use is called a front end. it's basically an easy to use 'face' over windows. personally, I use RoadRunner (it's free), it plays music through winamp, videos through WMP, and I use iGuidance4.0 for GPS (all are embedded into roadrunner).
3.) no, that doesn't present problems, but it does limit your PSU options. Carnetix makes a couple PSU models that can output the ~19v your EEE box requires, and they have secondary 12v outputs to power your HDD and monitor (with an optional 5v 'add-on' output).
4.) you can wire a switch if you want, but you don't want it to interrupt the power to the PSU. car PSUs wire up like an amplifier, they have an 'always live' constant power and ground connection, and a IGN wire to connect to your ignition switch (or any switched 12v source). if you put a switch on anything, it should be the IGN line, not a power line.
if you get a good PSU like the Carnetix P1900 or P2140, they both have integrated automatic startup/shutdown controllers that will turn your PC on and off with the ignition key. it has a delayed power off to allow your PC to properly shutdown before it cuts power.
if you want the ability to override your ignition (leave the PC on with the car off, or leave the PC off with the car on) then you can wire a switch on the PSU's IGN wire.
I installed an override switch for my system. I used a DPDT (center-off) mini toggle switch with a different colored status indicator LED for each override state. this is how I wired mine up:
if you don't want LEDs, then you can use a simple SPDT (center-off) switch like this:
good luck![]()
LinkBack URL
About LinkBacks
