Take power from a HDD connector.
The yellow is 12v.
The way my trunk is setup means that my harddrive is sitting on a 45 degree angle which isn't good for the drive at all. I was thinking about just using a portable harddrive to boot from but I need a way to power it. I have an m2-atx is there any way to power the harddrive?
It takes in 120v and converts it to 12v
Okay that worked I cut the power brick off of the cable and then ran a 12v and ground to the cable and it fired right up.
