Ok so I'm down to
wiring up my M1. The
power supply includes the Negative, Positive, and Ignition Wires (J11, J12, J13). These are short and need extensions obviously to reach the battery, ignition, and ground. My question is what gauge wire (approximately) would be adequate for these wires? I have 14 gauge running my to my speakers.
Also, the connection for the ON/OFF on the motherboard... is it safe to use the
connectors from an old computer motherboard, then just solder the end that doesn't have a connector directly to the pins? Or is there a better way of doing it?
Also, the wire running from the Power Supply to the battery... do I need a fuse (besides the one on the power supply) between the battery and the power supply? (Like the in-line used for the Amp-Battery wiring?)
Finally, I'm pretty sure that I get that the remote leads off of my amps come into the power supply, then go out from there so that the amps turn on after the computer. My question is where do they go from the power supply, do I just hook in to the old ignition wire coming into my dash from my old
head unit? That's what I've gotten through searches, but am still a little unsure.
Any help would be greatly appreciated.
Thanks in advance!
