Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Failure to hold standby state
  1. #11
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by Seth_jxl View Post
    Im starting to think that the issue is related to charging, when i give the batterys a charge from a 240v charger they will last for about 14 hours on standby.
    batteries like that are designed as emergency backup batteries. they would normally have a constant trickle charge keeping them at full capacity at all times until they are needed. in a car they are getting 'fast charged', but probably not for a long enough period of time to make them last all night.
    as nobb mentioned earlier, you would probably be better off with a deep cycle battery. normal lead acid batteries discharge quickly even when the devices draining it only draws low currents. deep cycle batteries can provide a more consistent voltage as the battery discharges, and can provide that voltage for a much longer duration.
    good luck
  2. #12
    Newbie Seth_jxl's Avatar
    Jul 2007
    Quote Originally Posted by FusionFanatic View Post
    hibernation basically does the same thing as standby, but instead of loading the current windows state into RAM, it stores it on the HDD instead. it takes a little longer than standby, but its still faster than a cold bootup.
    and you can always add programs to the 'startup' folder to have them launch automatically when windows boots up
    why would it have to power up, then turn off, then start again? it should just power up and stay on
    When you loose your stanby data due to the m2atx losing power, on the next boot the system will hang. I have just checkd out the hibernate thing and will give that a go, sounds good.
    Im friendly with the start up folder but it will never take you back to the song you last had let alone the play list. It seems ironic that a computer is unable to do what my in dash cd player will :P
  3. #13
    Jul 2007
    good luck
    yes, deep cycle batterys are looking like the next alternative i think. Is a normal car battery classed as a deep cycle? It appears to hold charge for longer than these sla's and charges quite quick.
  4. #14
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Well you only have about 28.4Ahr worth of SLAs, which isnt all that much. Thats why your voltage is dropping so fast. Decide on the battery to get by how deep you plan on discharging it regularly. Most deep cycles sold at stores (like for RV, marine) arent really deep cycles at all, they are just modified starter batteries. I would only discharge those to 80% DOD regularly. If you are going to discharge down to say 20% or lower DOD, then I would look at getting a more expensive, real deep cycle. Like the stuff they use in wheelchairs, forklifts, golfcarts.
  1. Sick and tired of hibernate failure....so..
    By bimmerpc in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 10-25-2007, 02:31 PM
  2. Hibernate automatically from standby?
    By jnorion in forum Operating System Optimization
    Last Post: 05-22-2007, 12:33 PM
  3. Computer doesn't resume from standby...Opus 120
    By senseless228 in forum Power Supplies
    Last Post: 10-04-2006, 07:04 PM
  4. Small bugs/nits
    By slojam in forum StreetDeck
    Last Post: 09-16-2006, 12:01 PM
  5. CD head unit remote amp turn-on - Can it be used to trigger standby?
    By mach5 in forum General Hardware Discussion
    Last Post: 06-18-2006, 05:45 PM
