Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Just got back my RMA'd M4...and guess what?
  1. #11
    Oct 2007
    NY
    nah im not using a M4, i was just lookin around and i saw u had a wavy display also. using a old ibm thinkcentre(which is tough as bricks) so not sure what the specs are on it yet.
  2. #12
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by LiCelsior View Post
    What power supply ARE you using? It has to be something to do with the power supply.
    When I run my PC with an AC/DC ATX PSU, it's perfectly fine...
  3. #13
    Oct 2007
    NY
    m2-atx
  4. #14
    Sep 2007
    m2-atx
    That figures!!! Mini-Box PSU...
    Is your M2 grounded to the PC chassis, or mounted in isolation?
    What about the peripherials? Is the HDD isolated or grounded to the chassis?
  5. #15
    Oct 2007
    NY
    well the psu is in the case and so is the HDD. i think i have my m2 grounded to the chassis though.
  6. #16
    Sep 2007
    I've experimented with grounding everything, and isolating everything...no change...
    However, when I unplug the video, the sound card static is a little less...
  7. #17
    Sep 2007
    Frank from Mini-Box suggested unplugging the video...
    He mentioned maybe a ground loop or an unbalanced ground?
    Can anyone shed light on this?
  8. #18
    Sep 2007
    What gauge wire are you running into your M2? Do you feel that it's getting enough current?
  9. #19
    Oct 2007
    NY
    its getting pretty good current, but imma try to up the gauge and see what happens.
  10. #20
    Sep 2007
    I'm looking at the ATX pinout, and there is only one 12v line on those!
    But four 5V lines and three 3.3V lines!
    I wonder if the PSU isn't supplying enough 12v juice?
    Does the PCI slot run on 12V or 5V?
