DSATX and Intel D945GCLF Mini-ITX Motherboard
I need help frоm dsatx experts.
Recently I bought Intel D945GCLF Mini-ITX Motherboard to replace old VIA C7 board, which started to give me some problems.
On Intels board with on/off cable connected to the dsatx - Hit ignition and the processor fan spins up, then few seconds later, shuts down. If I disconnect cable and briefly connect it to the board - it starts up and works fine. With VIA mb - everything is fine.
I've heard of similar problems with Intel boards, but never found solution to it.
Any help is greatly appreciated
I've traced this to bad controller. Got a new DSATX. Now it will start up properly, but will not shut down.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
