Results 1 to 4 of 4
Thread: Am I going in the right direction?
    Jan 2008
    Question Am I going in the right direction?
    I've read thread after thread, post after post... I thought I understood it, but after reading contradicting posts, now I don't. My project is still on the drawing board, and I'm trying to figure out the whole electrical side of my project, and if I'm on the right path...
    I want get power to the PC, a 4-channel amp, a Lilli 629, and maybe a USB hub. I have an '09 Scion tC, which came with a 6" sub, and it does what I want for now. (I'm in school, so I want to keep expenses as low as possible)
    I think it's something like this
    Battery (+) >> (<1-ft) 4awg wire >> amp fuse (within 18") >> 4ga wire (to back) >> power distribution block
    distro block >> fuse >> 8awg wire >> M2-ATX >> PC
    distro block >> fuse >> 8 awg wire >> amplifier
    with the lilli, I could connect to the M2-ATX?
    to ground everything, could I just wire the grounds from the PC and the amp to the chassis bolt? or would I need to do (ground wires >> distribution block >> wire >> chassis bolt)?
    Am I missing anything? I know this is a lot, and I'm sorry for that. I'm just trying to get in the right direction.
    Thanks for all of your help!
    Edit: I've re-read this FAQ (http://www.mp3car.com/vbulletin/faq-...-speakers.html) and I believe I'm on the right path. Just need a second (or more) opinion.
    Jul 2006
    seattle
    Yes!
    Yes you can wire the ground separately.
    The shorter the ground wire, the better.
    dsatx in voompc 2 case <HERE>
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You have it figured out correctly. One of the most important things is to ensure that all grounds go to the same location. That reduces the possibility of a ground loop.
    Want to:
    Jan 2008
    What a relief!
    okay, so I realized that I forgot to consider the ignition/accessory line.
    My cousin told me he wired his ignition from the radio harness to the m2-atx (which also sends the ignition signal to the amp, which I gotta learn how this works), would this work? If so, is it safe? How would I do this (properly)?
    My cousin also confirmed that you can connect the Lilli to the M2-ATX. I'm assuming the lilli comes with the connector to do so?
    Just two more obstacles to overcome...
    Thanks!
  1. Replies: 5
    Last Post: 10-22-2007, 09:40 PM
  2. Does my GPS tell direction (NWSE)?
    By nobb in forum GPS
    Last Post: 07-06-2007, 07:46 PM
  3. Direction Indicator for MM & FD
    By GizmoQ in forum RR Skins
    Last Post: 10-10-2005, 12:50 AM
  4. Replies: 5
    Last Post: 10-05-2005, 11:34 AM
  5. Direction Sensing Active IR Sensor Thing.
    By Mio in forum Hardware Development
    Last Post: 10-03-2005, 12:55 AM
