Nobody?
Got everything hooked up. Put in the power supply today. I took the ground and ran it to the ground on my amp. Then the ignition I put on the remote wire of my amp. And the battery I put to my circuit breaker because I relocated my battery. I have connunitunty on my ground, I have 13v on both ends and it still won't turn on.
I tried putting the ignition and battery to the circuit breaker no luck. I plugged in an external power supply to make sure the mb was working and it does.
The green light was flashing on the power supply (opus) then stopped all of a sudden.
So I got out my battery charger put the ground to ground and both positives on the + of the battery charger and it turns on. Then after a few min I couldn't get it to go back on. I know everything is working properly and I have good voltage and ground.
How should I go about troubleshooting from here on?
Nobody?
take it out of the car.
user your desktop atx power supply to test it. (follow this link: http://www.techpowerup.com/articles/other/22)
yellow wire to opus positive input
black wire to opus negative input
yellow wire to opus ignition input
if it doesn't work, you have a busted opus.
dsatx in voompc 2 case <HERE>
It does work with external power, just not with power in the car.
I'd be very surprised if you could blow up an Opus. So lets start at the beginning.
I am familiar with the Opus DCA7-150. Start with ignition off and with a multimeter confirm:
1. Disconnect all leads from the PS
2. Check the yellow fuse has not blown (remove it & check)
3. Is there power to the yellow wires (pin 4 & 5 of J1) all of the time? (to battery)
4. Check no power to the red Accessory wire (pin 3)
5. Turn Ign on. Is there power on the red wire (pin 3)? There should be.
If all is good at this point, turn off the ignition and check the output side (J5) with a multimeter. First without J5 connected, check you have a good earth to pins 2, 3, 6 & 7 (black wires) using continiuity with bare metal on the chassis.
OK if all is good we need to ocnfirm the PS is outputing power. This will be easiest if you set the PS to be in AT mode by shorting pins 2 & 3 on J6 with the supplied jumpers. Tis will disable all of the ATX handshaking.
connect J1 and turn the ignition on. What does the light do. It should glow solid. If not check the blinks against the documentation to diagnose the fault.
Check you have 12 volts (or whatever you have set the PS to output) on Pins 1 & 5 Back to the earth (pins 2,3,6,7). You should also measure the output on pins 4 & 8 against earth. You should have 5 volts.
Ok, you if you got this far, you know that you have got a PS working properly. You just need to figure out what power mode you need. I have got a laptop, so this is where we part company becasue Opus are working with me to upgrade the bios to support my laptop mode.
Note that you may need to configure setings in the BIOS so that the Opus starts your laptop.
Here is some info from Opus Tech support verbatum I received:
When a jumper is loaded on pin 9 of JU2, the power supply is configured to turned on / off the computer by the user ‘s action (pushing the power-switch button from the front pannel).
Since you have FW:20, the power-switch cable and the ignition wire are not used. Just the PS-ON cable connector and power output connector are connected to single board computer.
When a jumper is not loaded on pin 9 of JU2, the power supply is configured to turn on / off by the ignition switch. Your single board computer may need PS-ON signal connector (check your SBC specs for proper configuration) along with power-switch cable connector and power output cable connector.
Besides using sub-ATX mode (01), you also need to set AC Loss Power Restore ( in BIOS) ON so that when you power up the power supply, the laptop will be turned on.
Explanation of pin 7 and 8 of JU2:
Pin 7 of JU2 is used to set remote output delay turn-off. Operation is as follows:
If pin 7 is not loaded with jumper, remote output will turn off right before shutdown delay (set by jumpers on pin 1, 2, and 3 of JU1).
If pin 7 is loaded with jumper, remote output will turn off after ignition switch is turned off.
Pin 8 of JU2 is used to set startup and shutdown voltages for 12V / 24V input. Operation is as follows:
If no jumper is loaded on pin 8, startup and shutdown voltages will follow 12V input’s startup and shutdown voltage configurations
If a jumper is loaded on pin 8, startup and shutdown voltages will follow 24V input’s startup and shutdown voltage configurations
SO take your time and check each item one by one above.
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
Oh and I forgot to mention that there are some time delays on the Opus I think, so sometimes you need to leave it alone for a while before playiing again.
RodW
I'll have to look at that big post again.
So I don't need the ignition wire at all?
I have this all hooked up, ground to ground, ign to remote on my amp and power to the power on my amp. At first when I turned the headunit off the pc started to boot up. Now it's got a mind of it's own. Seems like sometimes it boots up when it wants and sometimes it doesn't. I have to keep turning the radio on/off.
Sorry If I have confused you.
Yes you do need to connect the IGN to the Opus (red wire pin 3) and then connect the Opus remote wire (pin 6 of J1 - blue wire) to the Amp remote. That way, the Opus will tell your Amp when to turn on after you apply power.
Have a look in the Opus user guide and follow the diagram on page 3 for a basic setup. Download it from Opus here:
http://www.opussolutions.com/pdfs/DC...ck%20Guide.pdf
What I was trying to get at is that you need to trouble shoot this in a logical fashion step by step starting at the caer end and working through each element one by one.
1. Check all of the power coming into the Opus (J1) is correct, confirm voltages with multimeter does IGN give you 12 volts? Does BAT give you 12 volts? Is there continuity to earth?
2. Connect the Opus and check output voltages with nothing installed and IGN turned on. It is best to do this in AT mode so the startup/shutdown handshaking is disabled by changing the links on the board. Do you get 12 volts on the yellow wires and 5 volts on the red wires?
3. Is there 5 volts all the time on the standby power connector with IGN on and off?
4. What does the Opus LED tell you? It should be solid on when powered up and flashing slowly when IGN is off (and power off delay times have passed) Check any flashing patterns against the document in the link above.
5. Does the AMP turn on? (Mine has an LED to tell me)
So if you have all of that sorted, then you will know the Opus is working fine & then you need to enable the appropriate links on the board to configure the startup and shut down as per the documentation in the link above.
RodW
