Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: EPIA-M with OPUS and USB stuff
    Dec 2001
    Texas
    Question EPIA-M with OPUS and USB stuff
    I will be getting my PS back from Kris on Tuesday but I have one major concern. The EPIA-M supplies power to the USB ports even when the system is shutdown. Do any of you have any ideas on preventing this from happening? I am going to have about 4 USB devices and don't want them sucking on my car battery 24-7 (I know the power supply should kick off before the battery is totally dead, but this is still bad for the battery).
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    A switch would let you control it manually ( I bet you already thought of that)
    Maybe the 12 v power line gets turned off by the egintion (sp?)
    Like original equipment radio installs.
    TruckinMP3
    Read the FAQ!
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Shouldn't the usb ports being fed power be a function of the motherboard and not the opus?
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Jun 2002
    Norway
    doesnt the epia have some sort of an option in the BIOS for this ?
    makes no sens to me why the epia should do this...
    Richardl...
    "If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
    Albert Einstein
    Dec 2001
    Texas
    Yes, it is a problem (for me) with the mother board. I could solve it with a switch, but that beats the purpose of the Opus. I hope I can chane something in the bios (other than turning USB off)!
    Dec 2001
    Maryland
    How about a powered USB hub wired to the OPUS. When the opus shuts down the Hub turns off and your device will get little or no power.
    2004 F350 Ext. Cab
    System not reinstalled in it yet
    Jan 2002
    Chicagoland, IL
    And are you sure that the devices are still getting full (100-500ma) power after the system is off? And are we talking off off? or just standby/hibernate/etc? After reading the usb spec, devices are allowed 500ua for remote wakeup, and high powered devices are allowed 2.5ma durring suspend.
    -Nick
    Dec 2001
    Texas
    All I know is theat the LEDs on my wireless nic and keypad stay on even when the system is shutdown. On my desktop the LEDs turn off.
    Sep 2000
    LA, CA, USA
    There is an option in the BIOS of the epia m that allows you to resume on a usb event. If you disable this I would think that would cut the power to USB devices.
    Dec 2001
    Texas
    az1324,
    Great idea! I already tried that (still have the bios set up that way) but no luck!
