Results 1 to 10 of 13
Thread: powering a usb hub
    Newbie elstev0's Avatar
    Sep 2005
    Elizabeth, South Australia, Australia, Australia
    powering a usb hub
    My problem is as follows:
    I have pulled apart my usb hub and connected a molex connector to the power input using +5v and -5v, everything works fine when connected to my pc at home running off 240v i can connect to all 4 ports and they all work fine.
    When connected to my car pc via my m2atx the power led comes on but i can only get my keyboard to work. I dont think ive run out of power as i can connect all the devices i want to run direct to the pc its just they wont run when i connect them to the hub.
    When i put the multimeter on im only getting 4.6 volts on the 5v rail, is this enough to power usb hub?
    My idea is to power the hub direct from the battery, do i need to install a 5v voltage regulator or is there a circuit i need to build?
    Any ideas more than welcome. Thankyou.
    Oct 2008
    7805
    I say try using the LM7805C voltage regulator. Or you could get a hub that does not require any external power. It takes its power from the pc.
    Sep 2005
    My goal is to power the hub from the car battery and conserve the pc's power and i cant find a proven way to do this.
    Oct 2008
    my point exactly mate. Use the lm7805c. its real simple to hook up and its way cheap. Its just input 12V, ground, and output 5V.Hook it up to your car battery and you're done!
    Sep 2005
    Awesome, thanks heaps.
    Oct 2008
    just make sure you attach a heatsink to this regulator.
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    You could also use a Point of Load PSU like this one:
    [URL="http://store.mp3car.com/Automotive_Point_Of_Load_DC_DC_15W_Power_Supply_p/pwr-022.htm"]Opus 15w POL/URL]
    This is what I use to power my usb hub. I just cut the transformer off the power plug it came with and wire the 2 leads to the output of the unit and it runs just above 5 volts (like 5.06v or something like that)
    Low Bitrate chrislamb's Avatar
    Nov 2007
    Warwick, UK
    MINI COOPER S PRO
    Sep 2008
    WTH? I have two powered USB hubs connected on the 5v rail of my power supply and they have both been working for years. What hubs are u using? Are they cheap? Have you checked the power supply's output to see if you're getting the proper power from there first? Where are you connecting the ground to?
    It will be much easier to have the hub connected to the computer then to regulators/battery, etc.
    Constant Bitrate Kalenth's Avatar
    Aug 2006
    DFW
    Quote Originally Posted by chrislamb View Post
    Your a genius! I had been looking into making something that did the same thing... a USB charger never came to mind.
  1. Powering a USB Hub with a mac mini + P1900
    By BGH in forum Power Supplies
    Last Post: 06-25-2008, 03:27 AM
  2. Powering USB hub with sirius power adapter??
    By kickercivic1 in forum General Hardware Discussion
    Last Post: 02-13-2008, 08:08 PM
  3. Opus 320 and 2 StarTech.com 7 Port USB 2.0 Hub
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-07-2008, 04:42 PM
  4. powering usb hub
    By toomuchtv in forum Newbie
    Last Post: 11-20-2007, 07:36 AM
  5. Powering a USB hub - an idea
    By Tim Lake in forum Power Supplies
    Last Post: 09-14-2007, 07:38 AM
