Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Random Shutdown/Restart
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    Question Random Shutdown/Restart
    Hello All,
    I'v noticed over the last month or so (since the weather has gotten colder), my computer seems to be automatically restarting under certain conditions.
    Now, i'v had the carpc for about 9mths now and just now getting this problem and jsut to add this is my first winter as i installed my system march08.
    First i would like to post my specs:
    DSATX PSU
    MSI MOBO W/Intel P4 2.4
    1GB RAM
    Dynex 5.1 PCI Sound Card
    AGP Video Card
    BU-353 GPS
    Lilliput 7" Monitor
    7 Port USB Hub
    hd radio
    DSATX Settings:
    Lowvolts=1160
    Vinhighthresh=1180
    vturnon=1
    Templow=0200 (negative 20)
    I have all my accessories being powered from a 30a relay which is powered directly from the battery. The only eletrical component i am tapping into is the ignition. I have a kill switch which is attached to my relay and then from the switch to my ignition.
    All my power (dsatx,2 amps) is being powered from a power distro block from the battery and same thing goes for my grounds. I have my lilliput, usb hub, hd radio power going to my dsatx molex connector and my grounds from a good ground contact point.
    At first i though it may be poor connection on my switch which is tied into the ignition, so i soldered the conections onto the switch, but the problem still remains.
    I have noticed my computer doesn't reboot everyday, but rather only in the morning when its a little colder. When i first get into my car the computer boots up fine and plays music.
    I only notice it will restart after about 5 min of driving and i have noticed it will only restart when i am completely stopped, it has never restarted while i'm driving. It will usually only restart once in the morning if its cold even after i warm my car up. Today it was just a few degrees below 0 and didn't restart.
    Driving home from work the computer never restarts, but i have underground parking, so car is warm.
    Its very odd it will only restart when i'm stopped and only first thing in the morning or when car has been sitting for a while. But when it does automatically shutdown all i do is turn my kill switch off and back on and it boots fine.
    On a day where the computer restarts in the morning, it will not driving home. Even if i'v been at home after work for a while and go out, i will autostart my car for 15 min and notice the computer will NOT restart and eveything is fine. Seems to only happen in early morning cold wheather and when i'm stopped.
    I'v had it restart 2 times one morning, which happened with in 15 min of driving and then it was fine.
    Any suggestions would be great and sorry for the long post, but i wanted to give as much info as possile.
    Cheers.
    Nov 2007
    Ottawa, Ontario
    Now i am thinking it has somthing to do with the lowvolts setting on the dsatx or maybe another setting on the dsatx.
    I have lowvolts set to 11.6 from what i remember.
    Does battery voltage drop lower when it cold? I just checked my volts when the car is off and its 12.5. So, when the car is at idle its probably above 14v.
    I'm thinking it has something to do with my low idle when i'm stopped and when its cold, but there is no way it would drop to 11.6 to initiate shutdown.
    Any ideas?
    May 2006
    Calgary, Alberta
    Yes, crappy OEM batteries (as far as I know) will not put out their full potential when they're frozen cold. And I've been to Ottawa in the winter.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Quote Originally Posted by TeamRSX View Post
    I would say check your alternator and see what the voltage is on idle. Could be a problem with your electrical system. See if the lights dim when your computer crashes. That is a good indication of not enough voltage.
    Or maybe your electronics aren't dealing with the cold too well. The crappy electrolytic capacitors used in most motherboards/power supplies can become out of tolerance in the cold
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by nobb View Post
    I dont think its a problem wiht the eletrical system as it only happends when its cold out. If it was a problem with the eletrical system it would be consistent in restarting which it is not . ALso it only happens in the morning when its cold, so most likely not a problem with electical system.
    I can't see if the lights dim when my computer crashes, becasue my computer doesn't crash, but rather shutsdown and shutsdown properly as the dsatx initiates shutdown timer when the computer restarts.
    Variable Bitrate PontiacGA's Avatar
    Mar 2006
    Pennsylvania
    If you turn the car off and leave the PC on, when you start the car again, does it turn off the PC...no shutdown? I have the same PSU and mine started doing this too since it's gotten cold and my battery in the car is about 6 years old. I'm thinking the battery is going. Time for an Optima.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
    Variable Bitrate jessekilner's Avatar
    Aug 2008
    Don't mean to startle the car battery idea but i run a converted laptop and i get same effect.. Now thats it's cold. It has internal battery so in theory it should only go into standby when the ignition power drops below the settings (battery low charge) but it just shuts down randomly, no standby just off. So my guess is the computer needs to be around a stable temp.. I would check the manufacturers of motherboard to see operating temperature range. My guess is it's above not below 32f. Otherwise try insulating the pc all around except for the cooling vent. Im gonna give this a try and see.. I'll post results in a week for a more thourough test. Remember the harddrive needs to be checked also as it's not designed for winter use.. Check the manufacturer of that device too..i bet we all will be surprised to see the results.and im certain this issue will get worse as the temps drop below 0'
    Did it.. Done it... now I got to keep the neighbors kids away!!
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by PontiacGA View Post
    when i turn the car off(assuming the car and pc are on) and leave the pc on it will still shutdown as acc goes low and will initiate shutdown mode, but if i have the car off, but only click the igniton to the second position so the car is not started the pc will turn on because i have vturnon set to enabled and vinhighthresh set to 11.8 so the pc will turn on even if the car is not running and as long as the volts dont go lower than 11.8v. BUt if i then start the car with the pc on it will initiate shutdown mode and restart the pc. Probably becasue acc goes low for just a few seconds.
    Its weird because i just upgraded my battery a few months ago from the stock one. I was originally going to get the optima, but didn't end up getting it. It definately has something to do with the voltage dropping i'm assuming. I guess a quick solution would be a capasitor as it would hold the voltage from the pc, but i really dont want to run one. I am leaning towards the battery though.
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by jessekilner View Post
    This could definately be another theory. My mobo i think is rated for 0 degrees celcius. But if it was too cold fo the mobo to startup why does it initially start up and then shutdown. This is why i am assuming it has to do with teh battery or voltage dropping. But right now i have the lowvolts on my dsatx set to 11.6v, so there is no way the voltage is dropping below that otherwise the car wouldn't start.
    Now i havent checked the battery voltage when its cold out to see what the voltage is when the car has beening sitting overnight in the cold. But in my parking garage at work i did some tests and while the car is off its 12.45v and when the car is on at idle its 14.45v. These are normal numbers, but it could be a different story when the car is sitting in the cold.
    It would be nice if we could pin point the problem. Its hard though as its not consistant. Good luck on your tests.
    Also, my hard drive is a laptop drive with gforce, but its also rated for 0degrees. I think though if the barings in the hard drive were too cold it wouldn't initally boot up. There is a number of things it could be.
    Mar 2006
    Pennsylvania
    I'm just wondering why mine just started turning off then back on when I start the car. The auto shutdown works after 10 min. fine as does the low voltage shutdown. But both of those actually shut windows down instead of just turning the computer off, then back on.
    Mike
    My Rides:
    '03 Vibe GT!
    My AED GA!
  1. Move Random / Repeat?
    By mbkowns in forum Centrafuse
    Last Post: 09-10-2006, 03:39 PM
  2. CF still has crappy random.
    By RPM_VR4 in forum Centrafuse
    Last Post: 08-05-2006, 04:01 PM
  3. vb6 Help generating a random number
    By J187 in forum Coders Corner
    Last Post: 04-08-2006, 02:49 PM
  4. Random...Little too Random
    By Prindle19 in forum Centrafuse
    Last Post: 01-17-2005, 06:30 PM
  5. MPXPlay / MPXF ... random play
    By DaBretty in forum Software & Software Development
    Last Post: 07-20-2000, 10:32 PM
