Results 1 to 5 of 5
Thread: DC converter with atx power cable to laptop safe?
    Apr 2007
    Is it safe to use a 12v -> 19V DC converter like this
    http://www.google.com/base/a/1409962...09194256985715
    To connect a m1-atx 12v out from the atx power cable, to a laptop?
    eg: splice the 12v out from the atx cable coming from the m1atx, attach it to the adapter shown above, and then plug the adapter into my laptop to get 19v it requires?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    That thing draws up to 80 watts, or 2.9 amps. Look up the technical specs on the M1-ATX to see how much power it supplies on the 12 volt rail. If you are using the M1 to power a PC, be sure to add that amount in as well.
    Question - why don't you just plug the adaptor into the cigarette lighter or wire it in directly? Why use the M1?
    Want to:
    Apr 2007
    Well i wanted to use the m1-atx as my startup/shutdown controller, cause i have an extra one laying around, and my carnetix 2140 that i was using recently died.
    But you are right, i dont think the m1-atx can power enough
    the adapter is 80w and the pc is 65w (msi wind desktop- does not have a atx power on the mobo - only 19v DC in on the back) On top of that i dont know how much the lilliput i have draws either...
    the pc and the lilliput and the dc convert off the 12v of the M1-atx i think will put it over the 2A
    Is my math correct? (i suck at it)
    I guess i should just shell out for a new 2140
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You can still use the startup/shutdown function of the M1. Just wire ONLY the startup/shutdown function of the M1 to your msi power switch.
    Then, wire your Lilliput to the M1 and you're done.
    Want to:
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    Quote Originally Posted by Bugbyte View Post
    I'd also control power to the 19v supply with the M1.
    Use it's 12v to drive a bosch type relay denying it power when the ssc is off.
  1. WTB: 20 pin ATX Power Cable for Opus 120
    By Shelbrain in forum Classified Archive
    Last Post: 02-04-2006, 02:23 PM
  2. Laptop vs desktop
    By wei2cool in forum General Hardware Discussion
    Last Post: 03-17-2005, 06:25 PM
  3. Replies: 7
    Last Post: 06-15-2004, 10:29 PM
  4. DC in to ATX converter board
    By MacBriar in forum Power Supplies
    Last Post: 08-11-2002, 07:29 PM
  5. what is the cheapest DC to DC ATX power supply available?
    By Squeezer in forum Power Supplies
    Last Post: 07-29-2002, 02:17 PM
