Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Engine noise with M2-atx
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    well i finally changed my inverter setup to and m2-atx, but this brought a couple issues, so here we go:
    my first issue is noise, with the engine running engine (alternator) noise that annoying humm, with the engine off i get hard drive noise, it crackles at the same time as the hard drive reads because i can hear the hard drive read and the speakers crackle at the same time.
    so knowing this i read bugbytes FAQ, and made sure that my grounding point to the m2 was nice and clean, and i also grounded the case to another point in the chasis, and in the mist of me doing this i first hooked up the ground to the case and lo and behold the pc started, so i proceeded to plug in the ground to the m2 and the noise is still there.
    now here is the funny part as i was cleaning my grounding points (with both of them unplugged so neither the case nor the m2 had a ground) i accidentally hit the power button to the pc and the thing started without ground! i remembered from bugbytes guide that the pc tries to ground through the speakers so i proceeded to unplug the head phone jack and the pc shut off, so i know what the issue is now.
    i also checked resistance at my grounding points and i had zero resistance according to my multimeter so for some reason my pc prefers to ground through the speakers and not the nice clean grounds that is has.
    i know i might need a ground loop isolator to get rid of the noise, i don't want to use one because it's not a real solution but i already have good grounds and i don't know what to do.
    and finally will i need an alternator suppressor as well or will the ground noise isolator take care of both noises.
    Mar 2005
    Rockledge, FL
    come on someone's gotta know this?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by Injector View Post
    Ground loops can be caused by grounding to different points. Is your radio ground to yet another point on the car?
    Best advice I can offer is to ground everything to the same point.
    Want to:
    Mar 2005
    Rockledge, FL
    it's the stock radio grounded by the factory.
    funny things is that before when i had an inverter i had no sound issues.
    Mar 2005
    Rockledge, FL
    oh and i unplugged the 3.5mm plug from the pc and plugged it into my laptop to see if it was RF and i had no interference just clean sound
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Right, so when you plugged it into a battery operated device that shares no electrical circuitry with the car, it has no noise. When you plug it into a device that does share with the car, you get noise.
    Try grounding your computer and your M2 to the factory ground for the radio. It sounds like you have each device (M2, case, radio) grounded to separate points. That makes it possible to introduce a ground loop from varying paths of resistance as the negative returns to the battery.
    I'll bet if you power the PC from a PSU that plugs into the wall, you won't get any noise either. You might try that and see whether it's true or not. That would tell you that the ground loop is from the ground points.
    Want to:
    Newbie maxq668's Avatar
    Oct 2007
    Boca Raton, Florida
    Try a SoundBlaster External USB card instead the onboard sound card from the mainboard. I had seen the noise issue on onboard cards quite too often...
    Mustang 2000 GT Silver
    LCD: 7' Xenarc TS
    Slot DVD-RW
    Mar 2007
    what did you tap into get you power. Fuse panel areas causes alot of noise issues. It best when you get straight from the battery then tapping into a power such as the radio.
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by Bugbyte View Post
    i tried grounding to the same grounding point as the radio and nothing the noise is still there, i'm abour to rip my hair out
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by maxq668 View Post
    i would if i had one, i'll ask my friends see if someone has one
  1. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  2. m2 ATX 160 Watt - voltage irregular?
    By MiniRX7 in forum Power Supplies
    Last Post: 11-16-2007, 11:32 AM
  3. M2 ATX installation trouble with ignition signal?
    By Snortonnorton in forum Power Supplies
    Last Post: 07-26-2007, 01:55 PM
  4. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  5. Bloomin' alternator whine
    By Vodkapete in forum Car Audio
    Last Post: 05-03-2007, 06:25 PM
