no -5 or -12?
Power :
http://www.just-married.ch/pt/dcdc/S...ints_Power.pdf
Supply 8-17V DC
+5V 5A (6A max) MAX787 freesample
+3.3V 5A (6A max) MAX788 freesample
+12V 1.8 A new design done with webbench
+5V stby 1A (linear regulator)
Fuse on board
Microctrleur PIC 16F84 4Mhz for the logic part
http://www.just-married.ch/pt/dcdc/S...ints_logic.pdf
- PowerGood
- SoftOn
- ATX Swicth with a relay (= power button of your case)
- Thermal switch (60°C cut of)
- 5V Stby Switch
- Enable/Disable power supply
- led de status (ON, STBY...)
- Input 12V accessory
Can be upgraded
5 I/O of the pic are free to drive more relay, temperature sensor…
Cost ~70-80 $
All part from www.farnell.fr except T6… (farnell=newark)
I will post the part n°...
All design made with protel
160x46 mmm
I will do the prototype + testing this month I hope...
Source Protel:
http://www.just-married.ch/pt/dcdc/DCDC_ProtelDXP.zip
http://www.just-married.ch/pt/dcdc/DCDC_Protel99.zip
no -5 or -12?
No...
It's specific to the EPIA motherboard (my own need...)
heh ok![]()
-12v and -5v can be easily made on a tiny daughterboard if you need them using one Maxim chip and and 3 support components. This is what I had to do in my system to get my serial port working as the PSU i made only supplies 5v and 12v (Cause I didnt think I would use the serial port - Now Im using TWO!).Originally posted by jol
no -5 or -12?
(=========-) 99% complete
AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
All jammed in external CDROM drive case.
Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
If you want you can mdify the design (you'll need protel) to add the -5V and -12V
As I use a T6 you can simply use it to generate the -5V and -12V
like on the original sproogy...
http://upload.nowherenews.com/files/20232952.jpeg
But on the mini-itx mainboard you don't need the negative voltage anymore...
And +12V is very usefull for the 3.5" hardisk (here I should get 1.8A cst)
Great idea!
But according to the schematics, T301 has one of its windings grounded. I've never seen such a thing before.
You mention this is being designed for the Epia. Is it for the Epia-M?
Keep in mind the compatiblity problems we've found associated with he OPUS and the Sproggy's. What are you doing different to make it compatible?
Well I made a redisgn of the +12V with webbench:But according to the schematics, T301 has one of its windings grounded. I've never seen such a thing before
http://www.just-married.ch/pt/dcdc/12V_sch.JPG
http://www.just-married.ch/pt/dcdc/12V_part.JPG
PCB will be done here:
http://www.olimex.com/pcb/index.html
with Solder mask layer,finish reflowed SnPb, white component mark, NC drill...21$ for 2 pcb!
Sorry I will upload again the logic part the pdf is a blank page...
http://www.just-married.ch/pt/dcdc/...rints_logic.pdf
