Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Just a quick Q :)
  1. #11
    Apr 2006
    It uses a 19v DC power supply (Circle head) which i run of an inverter mounted under my passenger seat.
    Certainly no performance issues with whats installed. Takes about 20 seconds to boot to windows and about 10-15 secs to shut down.
    I am using centrafuse as my front end with Map Point 2009 as my GPS. One thing to note is that i have stuck an extra gig of ram in it from factory spec.
  2. #12
    Apr 2006
    Oh....for detailed pics of the eeebox board look at this link
    http://www.anandtech.com/Gallery.aspx?id=121
  3. #13
    Sep 2008
    Alex - do you manually turn it on and off then?
    Thanks for the pics
  4. #14
    Apr 2006
    No mate.
    Basically you enable ACPI on the motherboard which is included with the latest bios update. What this allows is for you to set the machine to auto power on after a loss in power to the motherboard. Thus the scenario that when you turn the ignition off on the car the motherboard looses power from the invertor thus turning off (yes i shutdown before turning the engine off) When you start the engine the inverter starts giving power back to the EEEbox thus turning it back on.....Genius i say.
    You dont have to faf about with trying to get it to wake on lan and all that mollarky.
  5. #15
    Sep 2008
    Ahhh! It all makes sense now!
    Thanks for your help mate, sounds like a good system ;D
  6. #16
    Apr 2006
    anytime mate.
  1. Quick disconnect Box via cat5's
    By lostreception in forum General Hardware Discussion
    Last Post: 06-17-2005, 10:47 PM
  2. quick system disconnect idea
    By d_sellers1 in forum General Hardware Discussion
    Last Post: 05-14-2005, 10:35 AM
  3. opus and inverter quick q
    By sweetrobot2k in forum Power Supplies
    Last Post: 10-16-2003, 12:03 PM
  4. need win 98 SE quick!!!
    By cubanmoses in forum General Hardware Discussion
    Last Post: 08-10-2003, 07:47 PM
  5. HELP!! QUICK!!
    By iseff in forum General Hardware Discussion
    Last Post: 11-16-2000, 12:10 PM
