Results 1 to 2 of 2
Thread: Strange M2-ATX startup/shutdown
    Mar 2008
    Hey there.
    I have installed my M2-ATX into my car today and it is having a few problems.
    J1- constant +
    J3- Ignition
    J4- Negative
    J8- Motherboard on/off
    J10- Set to 5sec/45sec
    All the wiring has been checked and is correct.
    The problem I am having is that if I turn my ignition on, pc starts up as normal, but when I turn my car off the M2 does a hard off and doesn't allow the pc to shut down. What would be causing this? I had the M2 inside my house, powered by a normal computer power supply when I was setting my pc up and it always worked fine. When I unplug J8 and manually short it, the pc shuts down properly.
    After some more troubleshooting I think I have narrowed it down to my ignition wire.
    Everything works properly if instead of using the ignition wire to trigger the ignition, I use the constant 12v to trigger the ignition it all works. I don't understand this because my ignition wire should be doing this as it supplies 12v. Constant 12v is supplying 12.55V and the ignition is supplying a constantly fluctuating reading between 12.00V and 12.30v
    Sep 2007
    West Springfield, MA
    Sounds like you got the Ign and +12v lines backwards. The switched source should be the Ign on the M2.
  1. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 10:03 PM
  2. Xbox w/ M2 ATX and PSU convertor
    By MiniRX7 in forum Power Supplies
    Last Post: 11-25-2007, 06:45 AM
  3. m2 ATX 160 Watt - voltage irregular?
    Last Post: 11-16-2007, 10:32 AM
  4. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 04:36 PM
  5. m2 atx with hardoff=never
    By Nerd2 in forum Power Supplies
    Last Post: 04-10-2007, 08:53 AM
