swap your power and reset switch connectors, that's a sign that they're backwards.![]()
My DLYON is turning on when the unit goes into standby, and shutting off when the unit turns on. What gives??
Check out my CARPC: Project Diamond Plate
Quick Reference:
CPU Electrical Specs
Power Supply Calculator
Video Connections for newbies
Temperature Converter
Voltage Calculator
nope ive been using it this way for a year. no connections are backwards, it just all of a sudden wont power trigger the amp properly anymore. all other outputs and startup shutdown are normal
