Results 1 to 10 of 12
Thread: Intelligent Newb here, looking for some insight...
    Jan 2009
    So I came across a Dell OptiPlex GX240 computer for free and figured why not make a Carputer! The computer runs great as is, and i don't need to change anything. Now the issue of me getting a Dc-Dc power supply or a AC-DC power supply. I plan on running a decent audio system with a couple amps so I figure what the use of doing that If i'm going to get a annoying humming sound. So i'm almost passed the idea of an inverter, but the fact that this computer has such a small case makes me think twice about messing with a dc-ac inverter.
    I took a look inside and read on the power supply and it said 160W DC output. Any recommendations on what I should do? If someone knows of a DC-AC inverter that will not make noise, I would love to go that route...but if not, i suck it up and go dc-dc.
    Also, I saw a 150watt DC-DC power supply....is it possible that I will be ok with that? The only thing im using is a 10.4" monitor....everything else will be a factory dell setup.
    All input will be greatly appreciated.
    Oh, heres a pic of the computer so U can see where im coming from:
    factory power supply
    May 2006
    Simi Valley, CA
    This is most likely in the FAQs but you're always better off going DC-DC. If you really want to keep the case, you could remove the PSU and put a dc-dc on in it's place.
    Jun 2007
    one of the carnetix models might be what your looking for for your solution
    for your monitor if you don't have enough power you could probably pull some power from somewhere else or maybe add another battery which i doubt you'll need though
    Jan 2009
    Quote Originally Posted by GiODi View Post
    Well theres not really enough room to do a DC-DC in its place....its a much smaller case than it looks....
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    Smile
    Quote Originally Posted by evileagle17 View Post
    GiODi is giving you good advice. There are DC-DC psu's that can easily fit inside your case.
    DC to DC solutions produce much less heat, and are 35% more efficient than using an inverter. Efficiency= longer run time without starting the car.
    Elsewhere
    I think an ATX DC-DC is the best solution.
    However, I'm going to caution you. Dell is one company that is notorious for using standard ATX connectors but having non-ATX-standard wiring in those connectors.
    I don't know if the GX240 is one of these "not=quite-ATX" types, but you should find out.
    As far as space, the DC-DC ATX power supplies aren't exactly large. The odd form factor of the PSU in your photos looks like an M2 may fit in the same space with minimal hassle. Do some measuring and compare to the dimensions that are posted on these forums somewhere.
    You may need to fabricate some bracketry, but that's not particularly difficult.... Cut and bend some sheet steel and drill some holes for mounting.
    A Carnetix is NOT a good solution for this unit. A Carnetix unit is ideal only for systems that use "power brick" of some sort such as mini PCs and laptops.
    Your GX240 doesn't qualify.
    As far as noiseless inverters, you're going to be hard pressed to get a recommendation. We all recommend a DC-DC PSU for a vehicle PC, simply because the inverter adds a layer of complexity and inefficiency into the equation that you really don't need.
    The PC's stock PSU converts AC to DC. With an inverter, you convert DC to AC, then back to DC. A DC-DC PSU only needs to convert fluctuating DC to stable DC voltages. That generates less heat and is far more efficient than most stock PC PSUs.
    How about the Wiki?
    Jan 2009
    Quote Originally Posted by DarquePervert View Post
    So what do you think about this intelligent DC-DC... http://store.mp3car.com/M4_ATX_250W_..._p/pwr-031.htm
    It looks like it would be good power wise, and its decently priced. Will this work with the GX240?
    thanks!
    May 2006
    Simi Valley, CA
    I have a GX260 in my room and it has the same case: An M4-ATX would be a really snug fit, but an M2 easily fit. No modding necessary, just some double-sided tape.
    If you you'd like, I can take my M4 out of my car and see if it'll fit in there.
    Aug 2008
    The Dell PS is fully ATX compatible- I have one I'm using in a SFF unit
    Jan 2009
    That would be AWESOME cause I think thats the DC-DC im looking to get. I was thinking of taking out the existing power supplt, and mounting the dc-dc against the opening lid so that it would sit right next to the video card when closed.
    If you could check if that fits, I would be so thankful...........
  1. Review: M4-ATX 250 Watt Intelligent Power Supply
    By Bugbyte in forum The Review Palace
    Last Post: 12-21-2009, 09:52 AM
  2. PWR-015 & PWR-027 - M2-ATX(-HV) 160W Intelligent DC-DC PSU
    By RedGTiVR6 in forum Power Supplies and Regulators
    Last Post: 02-05-2008, 12:08 PM
  3. Calling all Insight P4-ITX owners
    By ShawJohn in forum General Hardware Discussion
    Last Post: 06-04-2007, 06:06 PM
  4. Newb question about power from a Molex
    By dsballer2000 in forum Power Supplies
    Last Post: 06-25-2006, 12:32 AM
  5. Insight P4-ITX
    By karaoke in forum General Hardware Discussion
    Last Post: 11-10-2005, 10:13 AM
