Results 1 to 2 of 2
Thread: Just a quick idea going through my head
    Jan 2009
    What sort of current drain does a typical ATX pc draw?? for example... will a 200w intelligent 12v psu power a normal ATX desktop system?? Maybe i should include the specs of what I intend to use:
    Dual Core 2.0ghz
    2gb DDR400 RAM
    DVD R/W
    Geforce FX 8600 GTS Graphics (maybe change as i know it's a big drain on power)
    USB Wifi dongle
    USB Bluetooth dongle
    I'm by no means a total newbie to the world of electronics / pc's, but i am fairly new to the idea of 12v power supply
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    there is no "typical" power draw, some PCs use less than 50watts, others use over 500watts.
    when determining the power requirements of a PC, there is no difference between a standard home (110v/220v AC) ATX PSU and a car (12v DC) ATX PSU. they both output the same voltages (+12v -12v +5v +5vSB +3.3v). whether using a home PSU or car PSU the same basic rule still applies; the PSU's total output wattage is a useless rating when determining the power needs of your system. you need to determine the current draw on the individual voltage rails (mainly the +12v and +5v rails).
    this FAQ has some good info as well as a link to a CPU electrical spec chart where you can find out your processor's power draw.
    you can find the amperage ratings for each DC-DC PSU in the mp3car store under the "technical specs" tab (under the product picture).
  1. Problem with my head unit.
    By Ederfico in forum Car Audio
    Last Post: 02-24-2007, 04:51 PM
  2. Taking internal amp out of head unit.
    By stonestatue in forum Car Audio
    Last Post: 01-19-2007, 02:28 PM
  3. Headunit Hacking.. Crazy idea..
    By ShinkunoNamida in forum General Hardware Discussion
    Last Post: 07-31-2005, 08:31 PM
  4. Remote Head unit Eject Problem FIxed!
    By Sporttracguy in forum Car Audio
    Last Post: 10-02-2004, 02:51 PM
  5. New Sony head unit - botched wiring...
    By SamDude in forum Car Audio
    Last Post: 09-09-2004, 05:21 PM
