Results 1 to 6 of 6
Thread: Can Carnetix turn your laptop on/off?
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    Can Carnetix turn your laptop on/off? I'm not quite sure what it means in the instructions, so is a second device necessary, such as this:
    http://www.mp3car.com/vbulletin/user...rn-module.html
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    the P1900 and P2140 Carnetix units have an onboard relay that shorts the power button leads (same way that webmaster's auto power-on module works).
    there is no need for a second device
    Nov 2007
    Long Island, NY
    Great! Thanks for the quick response. So no soldering is needed to my power switch now correct, because I just need to plug my laptop to the carnetix?
    May 2007
    Boston
    YES... soldering the power switch leads IS still required.
    the Carnetix units have 2 wires from the "ACPI relay". those 2 wires are the switch contacts of the relay. you need to connect/solder those wires to the power button leads.
    if a docking station is available for your model laptop and has a power button, then it may be easier to solder that switch instead
    Nov 2007
    Long Island, NY
    Fusion you have been more than helpful and simplified understanding this alot for me. Thank you.
    May 2007
    Boston
    you're welcome
  1. Carnetix Power to Laptop Wiring?
    By AznArkitekt in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-05-2007, 07:53 AM
  2. Anyone figure out how to turn on laptop?
    By RTman in forum General Hardware Discussion
    Last Post: 08-10-2000, 09:19 AM
