Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Yup, i just fried something on the m2 atx
  1. #11
    Jun 2008
    Houston
    yea thats part of the problem, i cant find it anywhere, or find any pictures of anything that looks like it. Also i tried un-soldering it and taking it off to better inspect it but i cant get it off, it feels like it may be more than solder holding it down. Or i could very well just not be doing it right. I may end up sending it back. I sent customer support an email, im still waiting on a reply.
  2. #12
    Dec 2008
    It's a quad line ferrite bead, hence the component designation FB1 or FR1. This is not a fuse but a filter component working similar to an inductor.
    http://en.wikipedia.org/wiki/Ferrite_bead
    Ferrite beads are similar to inductors in some ways but work especially in an area that is parasitic for general purpose inductors. They essentially act as a high impedance, or "resistor" to high frequency EMI/RFI electronic noise. The absorbed energy is converted to heat and dissipated by the ferrite, but only in extreme cases will the heat be noticeable.
    Same type of component at this one from Steward, but not nessesarily the same specifications:
    Datasheet: http://www.steward.com/web_info/CADP...0T0-10-D-2.pdf
    Website: http://www.steward.com/web_parts.asp...ower+Filtering
    The above mentioned Steward 29F0429-0T0-10 is sold among other places at these two online shops:
    http://mouser.com/Search/ProductDeta...OpHBLWAw%3d%3d
    http://search.digikey.com/scripts/Dk...me=240-2495-ND
    Just replace the burnt wire inside the ferrite bead with a new one with the same gauge, you can use the lead from a resistor or similar. And make sure the PCB tracks are not burnt away too or make sure to repair them by soldering some wire on top.
  3. #13
    May 2004
    it looks like a ferrite bead used to suppress RF Noise . If it is it it can safely be bypassed by jumping b+ to the fuse.
  4. #14
    Jun 2008
    Houston
    yall are god among men, thank you so much. Ill get to workin on it, i appreciate your help!!!
  1. M2 Atx .. qmm wires?
    By GreenBeauty in forum Power Supplies
    Last Post: 04-17-2008, 11:03 PM
  2. M2 ATX power supply wiring question... 3 terminals
    By Snortonnorton in forum Power Supplies
    Last Post: 07-25-2007, 08:25 PM
  3. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  4. m2 atx with hardoff=never
    By Nerd2 in forum Power Supplies
    Last Post: 04-10-2007, 09:53 AM
  5. Wtb :: M2 Atx Dc/dc Psu !!!
    By CoupeE46 in forum Classified Archive
    Last Post: 01-28-2007, 04:06 PM
