Results 1 to 4 of 4
Thread: Wire & fuse size for 360W psu?
    Jul 2008
    What size wire should I use for the Opus 360W psu? The psu itself uses 3x16awg wires for 12v input. I've got a 12awg solid copper cable (used for wiring houses) that I'm planning on using, but I'm not sure if it'll be enough. Also, what size fuse should I put in line with the battery? I've seen 20A for 150W, but I haven't seen anything said for any higher. The psu has a 30A fuse onboard; should I just use another one of those? Is there a good way to tell what size wire for what amperage, and what amperage for total input; or is it all just guess & check? Thanks.
    Jan 2008
    Dartmouth, MA
    You should go with the same size fuse that is on the PSU, maybe a little bit smaller if you don't plan on using the psu's full potential.
    For wire size look at the 12 volt table here:
    My Nearly Complete Car:
    Micro Control Center... Control Your Car Across the Internet
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    Variable Bitrate dMand's Avatar
    Oct 2007
    The Evergreen State, Washington
    I am using an 8Guage wire with that psu. Nevertheless, the wire rating calls for the use of a 10guage wire @ 8feet in length maximum, or 8 gauge @ 15 feet of wire max.
    Jul 2008
    Perfect! Thanks Paul.
    For thread preservation, the suggested wire gauge is 10awg @ 8 feet, 8awg @ 15 feet.
    beat me to it dmand ;-)
  1. FAQ: How do I power my DC-DC PSU on my workbench?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 12-14-2011, 07:55 PM
  2. Do I Need To Beef Up My Alternator Or Anything Else
    By chitown_16 in forum Car Audio
    Last Post: 12-05-2009, 11:10 AM
  3. Replies: 0
    Last Post: 04-03-2008, 08:30 PM
  4. Fuse Size Suggestions
    By TeamRSX in forum Power Supplies
    Last Post: 12-31-2007, 01:26 AM
  5. PSU power over speaker wire???
    By Defiler in forum Power Supplies
    Last Post: 02-20-2003, 07:48 PM
