Results 1 to 7 of 7
Thread: High Current Ammeter
    Jan 2008
    Dartmouth, MA
    Hi guys,
    I'm looking for an ammeter capable of measuring current above 100 amps. I have a pretty demanding sound system, will be adding a computer to that, and I'd like to be able to keep an eye on how much current I'm drawing at all times. My alternator is able to produce 120 amps, and my sound system can pull that much on its own assuming my trunk is 100 degrees and the volume is all the way up.
    Where can I find such an ammeter?
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Im guessing an ammeter capable of measuring 100 amps is going to be expensive. A cheaper method would be to buy a shunt resistor capable of 100 amps, measure the voltage drop across the resistor, then use ohms law to calculate the current.
    EDIT: nvm:
    http://www.outsidesupply.com/index.a...ROD&ProdID=254
    Might pick one up for myself.
    Jan 2008
    Dartmouth, MA
    Hmn, I had looked around for one and couldn't find one. Good find.
    Also, good call on the current shunt. I should have thought of that. Now I can get that info onto the computer's display.
    Jan 2008
    Dartmouth, MA
    Too bad these guys are so expensive...
    http://www.outsidesupply.com/index.a...ROD&ProdID=259
    That would make life so much easier.
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    I have one of these;
    http://www.sears.com/shc/s/p_10153_1...0P?vName=Tools
    It'll do 400 amps for $60.
    The only thing it lacks is peak hold, it would be fun to see how much current my starter pulls on a really cold day.
    Sep 2005
    Australia
    Quote Originally Posted by billmee View Post
    Hmmm, now thats a good idea. Does it have any kind of external interface, I have seen some meters that you can connect to COM or USB..
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by Civic Modz View Post
    I actually went out and bought this, and, unfortunately, it does not have an external interface.
  1. New OBDII scantool - Beta testers?
    By tmort in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 11-16-2012, 01:35 PM
  2. High Current USB
    By jayhawkclint in forum Power Supplies
    Last Post: 12-11-2008, 11:24 PM
  3. modified ATX (current mode)
    By xyz9915 in forum Power Supplies
    Last Post: 09-10-2008, 09:52 PM
  4. Auto High beams
    By nsgrossman in forum Hardware Development
    Last Post: 02-01-2008, 04:43 PM
  5. Is there any High Quality, High Res, Silm Design?
    By jackyyuen in forum LCD/Display
    Last Post: 01-03-2008, 06:57 PM
