Results 1 to 2 of 2
Thread: help... big big power issues...
    Jan 2009
    Arrow help... big big power issues...
    hey ppl... please help me... i m in a big problem, i am all confused about how to connect the three batteries, two auxiliary and one car battery using an alternator and isolator... whether to connect the pc to auxiliary battery or to the car battery, where to fix connect the amp and pc fuse. please help...
    Constant Bitrate Lincolnman's Avatar
    Nov 2008
    Fargo, ND
    I do not remember the details, but you can get a kit for this through the 4x4 supply places, as they use them for their winches.
    The two auxiliary might as well be hooked together through a normal "t" connection. They are to just be used as extra backup, yes? If the two auxiliary are intended for the carputer/stereo then they ought to be run to the electronics and only accept incoming voltage from the alternator (charging) but NOT allow the electronics to feed off the main battery. In this way the main battery can be isolated only for starting and the other two will charge but the power will "dead-end" at the electronics so that the main battery is never used for electronics, saved for starting.
    I probably made that sound WAY more confusing and complex than it is. Sorry - I have not had a lot of sleep.
    You will need one part of one of these kits, a large diode, I think. Anyway, google multiple battery set-ups.
    (...or go here -
    Electronics work on magic smoke - don't let it out.
  1. Replies: 115
    Last Post: 03-05-2011, 03:54 AM
  2. Review: M4-ATX 250 Watt Intelligent Power Supply
    By Bugbyte in forum The Review Palace
    Last Post: 12-21-2009, 08:52 AM
  3. Help a newbie with power issues
    By probability in forum Power Supplies
    Last Post: 06-17-2006, 03:27 PM
  4. Power Supply crank issues
    By jaytyn in forum Power Supplies
    Last Post: 11-03-2005, 12:44 PM
  5. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 12:13 PM
