Results 1 to 10 of 12
Thread: Can I power Carnetix 2140 from my capacitor?
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    I have a 1 farad capacitor in the trunk of my jeep liberty which powers my mono block amp for my subs, and my 4 channel amp for my highs. Can I also run my Carnetix 2140 from this as well? Or do I need to create some sort of direct connection straight to the battery?
    Jan 2008
    Southern Calif
    I would think it would be fine as long as it's receiving a good supply of juice.
    Nov 2007
    Long Island, NY
    Thanks Rg,
    I think my problem is that I do not have a large enough wire running to my carnetix from the cap. Which gauge would you suggest?
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    carnetix will output max 160W, i'd say 8 or even 12 gauge should be enough...look at the power wire harness o the carnetix, wires pretty thin...
    Elsewhere
    First of all, that capacitor doesn't truly power anything.
    It simply provides additional power in case the amp(s) draw more current than is available form the battery.
    Considering your audio setup, if you feel the need for a capacitor for your amplifiers, I would wire the P2140 straight to the battery and allow the capacitor to provide additional juice for the amps only.
    12awg should work for the Carnetix, as long as the run isn't too long. 10awg would be pretty much bulletproof. Anything larger would get a bit difficult to work with.
    How about the Wiki?
    Nov 2007
    Long Island, NY
    Thanks Darque. I knew that the cap doesn't provide power but I wasn't sure if I could use it as a distribution block for the Carnetix or no. I have decided just to create a direct run from the battery instead to make it a sure thing.
    Thanks for the advice guys.
    Elsewhere
    The only think you should use as a distribution block is...
    well...
    a distribution block.
    How about the Wiki?
    FLAC Dougw133's Avatar
    Nov 2007
    PA
    Dumb question...I am desperately trying to sort out some very odd USB issues. The only thing left I can figure is a power issue. I had a 500K (1/2 Farad) capacitor lying around a while back and threw it in before my distribution block for my PC and HD radio. I understand this isn't a battery or power source however, could it have negative impacts on my system>?
    Elsewhere
    Nice threadjack Doug...
    How about the Wiki?
    Nov 2007
    PA
    Quote Originally Posted by DarquePervert View Post
    Well I figured it was on topic. If that's a "Threadjack" then I am truly sorry. Forget it
  1. Replies: 115
    Last Post: 03-05-2011, 04:54 AM
  2. Review: M4-ATX 250 Watt Intelligent Power Supply
    By Bugbyte in forum The Review Palace
    Last Post: 12-21-2009, 09:52 AM
  3. how to power laptop and charge battery with carnetix
    By sharpmusic in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-29-2009, 07:20 AM
  4. I ditched the 2140 & made my own SSC...
    By loginfailed in forum Power Supplies
    Last Post: 02-03-2008, 01:03 PM
  5. FAQ: Will <insert PSU model> Power Supply work with my system?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 10-10-2006, 01:38 PM
