Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: How to connect laptop to Carnetix 2140?
  1. #11
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Threads merged as they are the same topic and OP. Don't double post.
    Want to:
  2. #12
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Quote Originally Posted by Bugbyte View Post
    Right, skip the brick. The Carnetix IS the brick. Connect the + from the Carnetix to the + of the laptop cable. This is the part that comes AFTER the brick and plugs into the laptop. Connect the grnd, or minus, from the Carnetix to the ground of the laptop cable.
    It's just like our Mac Mini's, the only tricky part is the auto turn on and there are tutorials on how to do it on a laptop.
  3. #13
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    Sorry Bug, I didn't mean to cross post like that, but I felt this title would get a better/more responses.
    Also, thanks a lot for the response. As I suspected I can just skip the brick completely and use the cable straight from the laptop. Google combinations like "Carnetix to laptop" and visa versa and you'll see what i mean about not being able to find a clear photo/description of what to do.
    My Carnetix is providing ample power as tested via the multimeter, so I'll try this out when I get home.
  4. #14
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    http://www.carnetix.com/installation...anual_V1_2.pdf Look at page 14 in the manual. Connect the red to the + on the plug and the black to the grnd on the plug.
    Note there are duplicate red and blacks. You can safely combine both wires together, then solder them to the laptop cable. Get some heat shrink tubing from Radio Shack and slip it over the wire before connecting the for a nice, professional look.
    Here's a nice guide on how to splice wires.
    If it is a barrel-type connector for the laptop, the outside is USUALLY for ground.
    Edit - changed title of thread for OP.
    Want to:
  5. #15
    Nov 2007
    Long Island, NY
    It worked great! Thanks guys!
  6. #16
    Low Bitrate Twinsen's Avatar
    Apr 2006
    Memphis, TN
    Would I need to follow this thread's idea to be able to power a standard mini-ATX Shuttle PC? I normally use an Invertor to power my Car PC's for the past 5 years or so, but now I have a 4-door Civic, and an Invertor may not be logical since I'd have to put it in the trunk or something out of reach...
  7. #17
    Jun 2007
    You will not be able to power an ATX mobo with this PSU.
  8. #18
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You need something beefier than the 2140. Use one of the online power calculators to decide the right size PSU.
    Want to:
  9. #19
  1. Power to Carnetix 2140, but no output??
    By Startingline13 in forum Power Supplies
    Last Post: 02-09-2009, 11:38 PM
  2. Carnetix P1900/P2140 and IBM T40 Laptop Power Question
    By l00kster in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-24-2008, 02:55 PM
  3. Laptop won't startup at ignition with carnetix
    By hypnotiq in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 04-09-2007, 12:58 PM
  4. How do I connect my carnetix to my aopen mini pc?
    By ViViper1 in forum Power Supplies
    Last Post: 01-04-2007, 01:29 PM
  5. carnetix and laptop
    By griz145389 in forum Power Supplies
    Last Post: 11-06-2006, 11:51 AM
