Results 11 to 20 of 26
Thread: Starting carputer with keyless entry
  1. #11
    FLAC WuNgUn's Avatar
    Sep 2007
    Yeah, the PSU knows when the PC is on...
    (Just saw your sig...SVT eh!? Nice...I have a SVT Focus)
  2. #12
    Low Bitrate Laminar's Avatar
    Oct 2008
    Yep, once I get some real progress I'll throw up a thread in the Worklogs section.
    For now, here she is with winter rims:
    1999 SVT Contour
    3.0
  3. #13
    Sep 2007
    The power supply should still trigger the PC to turn off when you turn the ignition off. You shouldn't need any special wiring at all for this.
  4. #14
    Sep 2007
    Actually now that I think about it some more what you should do is use a relay to apply power to the turn on wire, when the doors are unlocked, or when the ignition is turned on, that way when you lock the doors as you get out, the PC would shut down.
  5. #15
    Jan 2008
    Dartmouth, MA
    Heres what I would do.
    First stick a diode on the power source for the light.
    Send that over to a relay, but on the relay, set it so that once the light powers it on the relay uses the source that it switched on to continue applying power to itself, so that it only needs power for a few milliseconds and then holds itself on. Then as far as shutdown goes, wire another relay before that one which kills power when the car shuts off.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  6. #16
    Jan 2006
    Michigan
    Auto Start with Keyless entry
    Ford uses a tiered power up/down system in most of their vehicles. My truck(01 Superduty) has a power on state that comes on when the vehicle is unlocked. This remains on for about 10 minutes after the truck is shut down. I will be taping this system to cut and apply power to the startup/shutdown controller on the vehicle battery side. This will provide power normally when I start the truck, but will cut power to the controller to prevent battery drain if the computer hangs.
    You can do a google search to locate the wire diagrams.
    Note: you will need to use a relay to control the power. The relay is controlled from the vehicle's tiered power up/down system. PM me if you would like the schematic.
    DNR
  7. #17
    Sep 2007
    Quote Originally Posted by PaulF View Post
    I think you need 2 relays to make something like that work (latch)
  8. #18
    Constant Bitrate b3tts32's Avatar
    May 2006
    Arlington, Tx
  9. #19
  10. #20
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Injector View Post
    Thats is cool, I like that. At 16.99 you cant go wrong either.
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  1. Starting up my first Carputer install :)
    By Audiophile in forum Newbie
    Last Post: 11-09-2006, 07:07 PM
  2. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  3. keyless entry + remote start recommendation
    By cadence117 in forum General MP3Car Discussion
    Last Post: 12-20-2004, 08:12 PM
  4. Using the Keyless Entry Remote
    By Sinorm in forum Input Devices
    Last Post: 04-07-2004, 07:34 PM
