Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Starting carputer with keyless entry
    Low Bitrate Laminar's Avatar
    Oct 2008
    I have an Opus 150 DC-DC connected to a Shuttle X27D. The power supply is connected to my ignition +12V line so that it turns the computer on when I turn my car on. Startup time is fairly quick, but it could always be quicker.
    Now when I hit the "unlock" button on my key fob, it unlocks my doors and turns on my dome light for 30 seconds or so. Is there a way I could wire my power supply to come on with either the keyless entry's dome light output or the ignition line? It would be nice if the computer would start up upon unlocking and stay on once I start the car.
    Thoughts? Suggestions?
    1999 SVT Contour
    3.0
    FLAC WuNgUn's Avatar
    Sep 2007
    Probably not possible with a factory remote-entry...
    You could make a latch-relay, hooked up to the dome light, but then how do you unlatch it when you leave the car??
    Oct 2008
    Here's the wiring diagram I had in mind.
    This way the power supply would receive a signal to power up when either the keyless entry box turns on the dome light, or the key is turned to the "ignition" position.
    I believe I'd need some diodes where I drew the arrows, though, so that the dome light doesn't stay on all of the time, right?
    1999 SVT Contour
    3.0
    Sep 2007
    Okay, I see what your saying now...
    But if you don't get in the car and start it before the dome goes off, then your PC will shut off...you probably already knew that
    Your right with both diodes...go big, just to be sure...3A or so
    Oct 2008
    Quote Originally Posted by WuNgUn View Post
    Thanks for the confirmation on the diodes. I figured I'd just set the "back to idle state" delay such that even if the dome light shut off, I'd have enough time to start the car - I believe I can set a 20/40/60 minute delay time.
    1999 SVT Contour
    3.0
    Sep 2007
    The only problem I see is, usually when you shut off a car, the dome comes on as well, so when you leave your car, you won't be there to see the PC shut down...
    And if it hangs, that an extra 20/40/60 minutes of battery drain...
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    The easiest thing to do is to upgrade you keyless entry to a better one that has a remote starter built in. That way you start the car, the PC turns on and not only is the PC on but you just get in and drive away. They are so cheap nowadays.
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
    Sep 2007
    Or you could wire it up similar, with diodes of coure, to the unluck button, that way the unlock would trigger it, and not the dome light, so that you didn't have the pc turning back on when you opened your doors to get out.
    Sep 2007
    Good suggestion HiJack...
    Remote starters are pretty cheap these days too.
    Oct 2008
    Quote Originally Posted by HiJackZX1 View Post
    This isn't an option for me. My car has a manual transmission and using a remote starter would mean bypassing the clutch switch and leaving the car out of gear, which I'm not willing to do. A failed e-brake cable could leave me with a totaled car, I've seen it happen.
    Quote Originally Posted by punker248 View Post
    Or you could wire it up similar, with diodes of course, to the unlock button, that way the unlock would trigger it, and not the dome light, so that you didn't have the pc turning back on when you opened your doors to get out.
    I like this idea, but it would definitely require a shutdown delay. I could just wire up an additional button to the shutdown jumpers and hit that as I get out of my car. That way I wouldn't have to worry about the 20 minute battery drain.
    Am I correct in assuming the power supply is smart enough to know whether or not the computer is currently on? If not, if I were to manually pulse the computer to shut off, then 20 minutes later the power supply blindly sends the computer another pulse, it would turn the computer back on. Is this the case?
    1999 SVT Contour
    3.0
  1. Starting up my first Carputer install :)
    By Audiophile in forum Newbie
    Last Post: 11-09-2006, 06:07 PM
  2. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 05:34 PM
  3. keyless entry + remote start recommendation
    By cadence117 in forum General MP3Car Discussion
    Last Post: 12-20-2004, 07:12 PM
  4. Using the Keyless Entry Remote
    By Sinorm in forum Input Devices
    Last Post: 04-07-2004, 06:34 PM
