Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: M2/car problems
  1. #11
    May 2008
    Well, I've already bought the M2, as is apparent from my posts in this thread, and all the threads I'd read on here before buying it were positive comments. Since then, I've read some problems/complaints, but what I'm experiencing sounds like it's more likely a problem with the battery power being interrupted briefly when turning the key from ACC to OFF.
  2. #12
    May 2008
    Well, scratch that... The voltage on the constant power from the battery is staying constant, but the M2 isn't switching properly. Something else I just found out now because I tried for the first time is that if I have it set to ACC and then crank the car, it restarts, as well. Unfortunately, I don't have room for the Opus board where I have my computer mounted. I'll try looking into other options, though. If need be, I can probably just wire something up with a power relay and a PIC processor to do the startup/shutdown and just use the M2 as a dumb DC-DC PSU.
  3. #13
    Jan 2008
    Dartmouth, MA
    It restarts itself because the crank of the engine is stealing all the power from it. From what I've researched, most power supplies cannot withstand an engine crank however there are a few that can. In the case that you have one which cannot survive a crank, your option is to create a tank circuit.
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
  4. #14
    Newbie elstev0's Avatar
    Sep 2005
    Elizabeth, South Australia, Australia, Australia
    I would look at how you have it connected first and at the electrical (battery & charging system), i have had my m2 running for years now running all my peripherals without any problem.
  5. #15
    FLAC WuNgUn's Avatar
    Sep 2007
    Double check your jumpers...
    None of this is going to fix your sound problem either.
  6. #16
    May 2008
    @ Wungun: Are there any jumpers other than the shutdown timing jumper that I'm just missing? I've tried several settings of that jumper, and while it does give DIFFERENT results, it doesn't ever give the RIGHT results. Regardless of the jumper setting, it cuts power to the computer immediately for a split second (enough to shut off the computer and cause the LCD to blink off) when ACC goes off (no change when going from engine on to ACC setting with the key, though, as it should be). I currently have it set to 5sec/1min so it won't continue giving power for a long time after I exit the car, but if I have it set to a higher setting, it will typically cut off immediately, and then after off-delay time, it will turn back on until hard-off cuts it back off. If I try using the power button while the car is running, I can turn on and off just fine, and once it is on, the computer works fine.
    Sorry to OP if I'm derailing your thread, but hopefully solutions to either of our problems will help the other.
  7. #17
    Jun 2007
    Im not running an AC-DC power supply in my car. I have this in my appartment.
    I have everything i could think of to try and diagnose the problem. I belive it is a problem with the M2/M4 not adhearing to the ATX spec or somthing. I was looking around and found this guy having troble with his M4 and a xonar D2
    http://vip.asus.com/forum/view.aspx?...Language=en-us
    and then looking at the change log makes me worried
    http://www.mini-box.com/site/resourc...fk5qMSAV1EhrR1
    you shouldnt change a hardware product and still call it the same thing. it might be that one of thoses changes in the last year or so that i bought it fixes the problem i am having.
    I have tried adding in a diode to my IGN line to try and see if that would effect anything. Tried wiring both 12+ and IGN to 12+ and when i turn my car off it still restarts. So anyother ideas would be appreciated.
    Also was looking at the Opus and was wondering why the 320 they are selling in the store is 230 and the 360 they are selling at opussolutions is only 188? is the 320 that much better or they just marked up the price that much.
  8. #18
    Jun 2007
    Quote Originally Posted by chibimateo View Post
    Acutally you nearly described one of the problems i was having almost exactly
  9. #19
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by Virac View Post
    Probably just markup. That's a common thing for a retail business to do.
    I'm really only posting here to subscribe to this thread, I'm interested to see the outcome.
    Tidder
    Try RevFE
  10. #20
    Jun 2007
    Quote Originally Posted by Tidder View Post
    Markup on a 40 watt less power supply.
  1. Replies: 33
    Last Post: 03-28-2008, 02:18 PM
  2. any known problems running under bootcamp
    By Ryan711 in forum MacCar
    Last Post: 09-13-2007, 03:00 PM
  3. Replies: 2
    Last Post: 08-13-2007, 03:18 PM
  4. Harddrive problems (booting)
    By Axxess in forum General Hardware Discussion
    Last Post: 05-15-2007, 04:13 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 01:55 PM
