Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: M2/car problems
  1. #21
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by chibimateo View Post
    @ Wungun: Are there any jumpers other than the shutdown timing jumper that I'm just missing? I've tried several settings of that jumper, and while it does give DIFFERENT results, it doesn't ever give the RIGHT results. Regardless of the jumper setting, it cuts power to the computer immediately for a split second (enough to shut off the computer and cause the LCD to blink off) when ACC goes off (no change when going from engine on to ACC setting with the key, though, as it should be). I currently have it set to 5sec/1min so it won't continue giving power for a long time after I exit the car, but if I have it set to a higher setting, it will typically cut off immediately, and then after off-delay time, it will turn back on until hard-off cuts it back off. If I try using the power button while the car is running, I can turn on and off just fine, and once it is on, the computer works fine.
    Sorry to OP if I'm derailing your thread, but hopefully solutions to either of our problems will help the other.
    You need to use the P1 settings as explained in the manual...are you sure you have pin 1 correctly identified? Make sure your not jumpered on P8 by mistake.
    You should not be able to hook up a switch to the board instead of the M2 and switch the PC on/off.
    Also, are you sure you have the power + and - and the ACC wired in correctly?? Sounds like you could be powering the PC off the ACC line instead of a dedicated power line...
    Read the manual...then read it again, and then one more time to be sure
  2. #22
    Sep 2007
    There is a thread somewhere describing your problems with a solution...check the M2 and M4 topics...
    Also, I think the leads for the ATX switch on the M2 are polarized. Make sure you get the + with the +
  3. #23
    Jun 2007
    Ive tried swapping the power-on leads, swapping the +12V and IGN, tie both +12V and IGN to +12V and all the behaviors lead me to belive that i have it wired correctly. Everything, minus the sound card, will work properly on my lab bench in my appartment, but when i put it in my car it doesnt work properly. i dont get it.
  4. #24
    May 2008
    Quote Originally Posted by WuNgUn View Post
    I'll check the Pin 1/Pin 8 as you mentioned when I get home (I'm at work now, and I don't have the manual in front of me, either), but from what I'd seen of the settings, the jumper settings have been relatively following what I would expect, minus the power being cut momentarily when ACC is turned off.
    I'm not hooking a switch directly to the board (though that actually should work fine, since P9 is actually just wired in parallel to P8 according to the manual); I have the switch hooked to P9, as it is designed to do.
    I checked the connections to POS, GND, and ACC several times before connecting it in the first place, and from what I'm experiencing, it doesn't sound possible that I could have any of those mixed up (it still has power to the board when ACC is turned off, aside from the moment it is turned off), but I'll check those again.
    I've read and reread the manual probably close to 100 times, including times before I bought it when I was just researching the functionality, but I won't discount the idea that I could be missing something.
    From what I've read about the polarization on the pins, I wouldn't be able to get the level of functionality I currently have if it wasn't polarized (and I've also read that the polarization is no longer an issue with current boards, which mine should be), but I can check that, too.
    If you happen to know what thread talked about the solution you mention, please send it our way. I've looked all around at anything mentioning the M2 that I could find, but I hadn't seen any actual solutions.
  5. #25
    Sep 2007
    I would suggest checking out the online manual...maybe something changed?
    Also, here are some links. If you can't figure it out after reading these, then maybe you need to RMA the M2, sell the replacement, and buy an OPUS...
    http://www.mp3car.com/vbulletin/powe...r-problem.html
    http://www.mp3car.com/vbulletin/powe...c-reboots.html
    more M2 issues.... ;-(
    http://www.mp3car.com/vbulletin/powe...m2-expert.html
    m2 atx
    New M2 issue
  6. #26
    May 2008
    @ Wungun: Thanks. I'll check those links out and see if they help. From the looks of the URLs, it looks like threads I've already read, but when I have more time this evening, I'll look through them and see if there is anything I've missed or haven't tried.
    As far as the manual, I've looked through the one hosted on mp3car.com, as well as the one on mini-box.com. They have a few differences (the one on mini-box.com is more updated with info about jumper settings on the D pins as well as the 1 minute latching of power after startup), but neither have any information that helps with this problem.
    More and more, it looks like doing the RMA on the M2 is probably going to be necessary, but getting the Opus is NOT a solution. I've mentioned it before, but I don't have the space in my install for the Opus, and from everything I've seen, a properly functioning Opus (any model) won't give me anything better for my purposes than a properly functioning M2.
  7. #27
    Newbie elstev0's Avatar
    Sep 2005
    Elizabeth, South Australia, Australia, Australia
    Where are you taking your 12v power from? Do you have a line directly from the battery or are you wiring to something off the acc line?
  8. #28
    Sep 2007
    Quote Originally Posted by elstev0 View Post
    Good point...the + and - going into the M2 MUST be constant, not switched!
    The M2 must always have the power available, whether the car is on or off.
    I'm having a 'Duh!' moment right now...lol
    That HAS to be the issue...
    Good one elstev0!
  9. #29
    May 2008
    12V constant power is like so:
    Battery + --> fuse --> 4g wire --> distribution block --> 8g wire --> M2
    Ground is similar:
    Chassis ground --> 4g wire --> distribution block --> 8g wire --> M2
    The switched line comes from the radio harness, but that's the only part that's switched.
    Also, it would be impossible to have my problem if the full power was connected to a switched 12V source: (aside from the cranking problem, which is really not an issue to me) when the key is turned off, it loses power to the computer momentarily (but my multimeter doesn't show any drop in the battery voltage, so it's either too short for the multimeter to detect or it's only happening on the M2 output), but then has power, so the computer can stay on after the key is out (and therefore no switched power).
  10. #30
    May 2008
    m2 atx
    New M2 issue
    I read through those threads and I'd already tried everything that applies to my situation aside from 2 things:
    Haven't tried a capacitor in parallel with the battery. Honestly it's a pretty awful idea in that place for the reasons explained in various threads here.
    Haven't tried a tank circuit. I'm not altogether opposed to this, but it would be a pain to do more routing of wires for that and finding a place to store the battery, and it would be shelling out money for something I really shouldn't need. I may end up resorting to this, but I think RMA on the M2 is a higher priority than that, since the M2 SHOULD be doing everything that the tank circuit is trying to fix.
  1. Replies: 33
    Last Post: 03-28-2008, 03:18 PM
  2. any known problems running under bootcamp
    By Ryan711 in forum MacCar
    Last Post: 09-13-2007, 04:00 PM
  3. Replies: 2
    Last Post: 08-13-2007, 04:18 PM
  4. Harddrive problems (booting)
    By Axxess in forum General Hardware Discussion
    Last Post: 05-15-2007, 05:13 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
