Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 43
Thread: M2/car problems
  1. #31
    FLAC WuNgUn's Avatar
    Sep 2007
    Quote Originally Posted by chibimateo View Post
    The switched line comes from the radio harness, but that's the only part that's switched.
    Huh?? You realize that most cars kills power to the radio and some electronics when you fire up the starter motor to protect them from feedback?? Why didn't you connect the M2 directly to the ACC wire at the ignition switch?
  2. #32
    May 2008
    Quote Originally Posted by WuNgUn View Post
    That may actually be a legitimate concern if that is the case. This is the first time I've heard about this (though it makes sense that it could be the case), and I'd actually seen everywhere I'd looked (mostly on here and 8thcivic.com forums) recommending to connect there. I'll try looking around for the ACC wire at the ignition switch tonight and see how that goes. Thanks!
  3. #33
    May 2008
    That was totally it! It now works perfectly after I spliced it into the orange accessory wire in the ignition harness!
    Thanks Wungun!
  4. #34
    Sep 2007
    Thanks Wungun!
    I knew we would get 'er
    Glad I could help.
  5. #35
    Feb 2007
    Glad I could help.
    I'm guessing that the issue with the Asus Xonar is still valid though, right?
    From my readings on this card I've learn that it requires a separate power supply using a 4-pin molex normally used for HDDs and CDROMs.
    Perhaps the M2-ATX simply doesn't cut it power-wise for this soundcard?
    I know that its a rather heavy consumer on electricity when compared to other products... Especially the new Essence STX with its crazy on-board AMPs...
  6. #36
    Jun 2007
    The Xonar D2 doesn't have a power connector for it it pulls power from the pci connector.
    My car has is wired like this
    Batt------4ga wire------Distrib block--------Amp power line and M2 12+
    Amp Gnd line and M2 Gnd------------Distrib block----------Car chassis
    Car IGN wire--------diode->|--------M2 IGN
    I believe that it is the White IGN line i am hooked into. And the Orange wire is my dimmer line.
    I have a new Opus 360V on order hoping that will make my Xonar work and fix this problem.
    edit: fixed the text art
  7. #37
    Sep 2007
    Quote Originally Posted by Virac View Post
    I ran my Xonar's on two seperate mainboards, and the M4 couldn't power it...
    The Opus didn't even break a sweat.
    Yeah, the Xonar D2's don't need external power...
  8. #38
    Jun 2007
    Ya i just got an OPUS DCX6.360 from UPS today hooked it up and all of my electrical problems went away.... but created a new problem
    the opus is about 2ce the width and about an inch longer in length. how does everyone else have this mounted in a case. or do you have an external case for it?
  9. #39
    Sep 2007
    Good to hear...
    I just have mine mounted on the side of my MDF 'case'...can't really see it here, but it's below the top-right fan...
  10. #40
    Feb 2007
    Will the M4 power a single Xonar?
  1. Replies: 33
    Last Post: 03-28-2008, 03:18 PM
  2. any known problems running under bootcamp
    By Ryan711 in forum MacCar
    Last Post: 09-13-2007, 04:00 PM
  3. Replies: 2
    Last Post: 08-13-2007, 04:18 PM
  4. Harddrive problems (booting)
    By Axxess in forum General Hardware Discussion
    Last Post: 05-15-2007, 05:13 PM
  5. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
