Results 1 to 7 of 7
Thread: Low power on USB
    Feb 2009
    Denmark
    Low power on USB
    I have an M2-ATX power supply, connet to a Intel Atom motherboard.
    My problem is that USB ports do not get enough power, rather than those on the motherboard.
    Touch screen works + my GPS, but if I take my 3G modem or a flash pen, the computer comes with an error that Windows can not recognize the device and it is even if only 3G modem which sits in.
    I've tried with a USB hub, with 230V adapter and it works. I made a wire from the M2-ATX 5volt to the USB hub, but it does not work.
    Any ideas?
    Kim
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I think you found the solution - a powered hub. It sounds like you haven't powered the hub form the M2 properly. How did you hook it up?
    Want to:
    Feb 2009
    Denmark
    I took a Y-Cable and put it together with the M2 ATX-connector cable with drive power connectors (HDD) - Just red (+5v) and black (-5v)
    Is it the right way to do it?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    How did you connect it to the USB hub?
    Want to:
    Feb 2009
    Denmark
    From the including 230V adapter, I cut the cord and put it together with the Y-Cable.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    Sounds like you hooked the power to the hub correctly, BUT... some hubs need more than 5V. Check the wall wart you cut off to see what it says the output is. It may be 6V, 7V, or something more. If it says 5V, then you should be able to get it working with proper connections. If the hub needs more than 5V, your best bet is to go and buy a different one that will use 5V.
    ~Jimmy
    Feb 2009
    Denmark
    Yes, the hub just need 5v and 3amp
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 08:35 PM
  2. USB power issues - opinions please
    By zaxxon in forum Power Supplies
    Last Post: 07-20-2005, 10:03 PM
  3. Laptops, Standby and USB Power Idea
    By matthewtoney in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-17-2005, 10:38 PM
  4. Usb power and Standby
    By dmcdlrn in forum General Hardware Discussion
    Last Post: 05-24-2005, 08:36 AM
  5. The "Official" low profile card post
    By lakorai in forum General Hardware Discussion
    Last Post: 05-22-2005, 08:49 PM
