Page 24 of 27 FirstFirst ... 1415161718192021222324252627 LastLast
Results 231 to 240 of 261
Thread: power supplies with minimal radio interferance?
  1. #231
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    All feed-through caps have a solid wire straight through the centre, usually with a solder eyelet on each side.
    The wire is encased by the capacitor which is connected to ground (the case) The action of the wire passing through case via the parallel connected capacitor causes any RF on the wire to see a low impedance to ground. RF is bled off the wire and coupled into the inside of the case. There is no way for the RF to bypass or radiate around the cap. This is not the case with a toroidal choke or ordinary bypass cap method where sharp rise time noise can couple around normal bypass methods and continue to travel down and therefor radiate from the cable.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
  2. #232
    Apr 2012
    eh.. sorry, this is a crash course in caps (electronics) for me.
    I'm still confused as to where the two ends of the wires are connected and to what. In my previous post, I added a picture showing where I think they are connected.
    One wire enters from the right and is soldered to the tip of the left as per you post (the red).
    Where is the 2nd wire soldered to the cap?
    JJ
  3. #233
    Sep 2009
    Australia
    No problems, RF is totally different to DC and audio. A piece of wire 1/16 of an inch long can look like an open circuit at high RF frequencies.
    In a normal FT cap there would be a solder end at each red mark (either end of the cap) This is a straight through wire connection but cemented into the cap. Those red marks you show are physically on each side of the PCB. In you case with these caps you have to put a single wire going through the cap and soldered it at one end. You now have two connections, physically one either side of the PCB passing through the cap.
  4. #234
    Apr 2012
    Oh. The light-bulb just came on. Maybe.
    Like this picture:
    JJ
  5. #235
    Sep 2009
    Australia
    Yes, remove some insulation from the wire where it needs to be soldered and when you solder it to the cap make sure you solder it completely around the wire, no gap. You could use long cables and terminate each end at the correct length, would make a tidy neat install.
  6. #236
    Apr 2012
    finally there. Thanks!
    JJ
  7. #237
    Sep 2009
    Australia
    No problems, glad I could help in some way
  8. #238
    ibf
    ibf is online now
    Oct 2010
    @John
    Any luck with the mod? Im curious how much improvement it would make.
    Apr 2012
    I finally completed the build this weekend, but ran into a problem during testing.
    I can turn the computer on and enter BIOS configuration and leave it there. All good, even after 30min its still in the BIOS configuration screen. No crash, no problems.
    When starting Windows, it resets during boot. After autologon and during init of the various bits and pieces, the computer just resets, as if I had pressed a reset button.
    Tried using an old ATX cable and it boots fine so the mod is causing the problem. But what?
    JJ
  10. #240
    Sep 2009
    Australia
    The only things I can think of are a poor cable connection or the gauge is too small or too few cables to carry the current for a higher CPU load during the boot process.
  1. HD Radio Commands
    By MGD in forum Road Runner
    Last Post: 07-23-2009, 03:01 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
  3. Joining 2 power supplies ??
    By vicky_obee in forum Power Supplies
    Last Post: 05-18-2006, 07:03 AM
  4. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 10:32 PM
  5. Opus power supplies ---> for AMD mobile???
    By folagana in forum Power Supplies
    Last Post: 09-08-2004, 07:39 PM
